Old 10-20-2019, 06:29 PM   #1
40cpe
40cpe's Avatar
Default Old door seal removal
On my '38 car, the door hinge seals have turned into a gooey tar-like mess sticking to the door. Part of the seal has hardened, too. What to use to remove the mess without damaging the paint? I've tried lacquer thinner and it doesn't seem to stay on the vertical surface long enough to help.
Old 10-20-2019, 06:57 PM   #2
V8COOPMAN
V8COOPMAN's Avatar
Default Re: Old door seal removal
3M has some really good products. I've used this stuff very successfully in the past. They also have similar in spray cans. Good paint supply stores should stock it, or Amazon. DD
Click Links Below __
T5 W/TORQUE TUBE
Old 10-20-2019, 08:04 PM   #3
J Franklin
J Franklin's Avatar
If you don't want to damage paint don't use lacquer thinner!
Old 10-20-2019, 09:44 PM   #4
fordor41
fordor41's Avatar
I used adhesive remover from Autozone. spray can, works really well on old adhesive
fordor41 is offline   Reply With Quote
