Old 07-04-2021, 11:23 AM   #1
GPierce
GPierce's Avatar
Default Worn-out Distributer Cap Carbon Brush
500 miles on new A-12115 Distributer Cap. ??
I was checking the newly installed original points from NAPA as my timing had changed slightly at 500 miles and found this. I expected the point gap to close up slightly but not a worn out rotor brush. Noticed the brass particles when I glanced at the cap and thought gee I need to investigate where those brass particles came from.
GPierce is offline   Reply With Quote
Old 07-04-2021, 11:53 AM   #2
J Franklin
J Franklin's Avatar
Default Re: Worn-out Distributer Cap Carbon Brush
Check or replace the rotor as needed. Was it fully seated in the down position?
Old 07-04-2021, 12:42 PM   #3
GPierce
GPierce's Avatar
I also installed new rotor. Good point, the rotor was fully seated I thought as there just a little springy feel as I set the cap on. Not being fully seated would certainly cause that problem.
Old 07-04-2021, 06:06 PM   #4
Chuck Sea/Tac
Chuck Sea/Tac's Avatar
I would think Brass particles are from the rotor or body terminals. You need to “ with no side play” on your rotor shaft, set the gap to around .025” on all four body tits. Also check to make sure all four lobes of the distributor cam give you the same point gap. As for the carbon button wearing out prematurely, you may not have had the rotor fully seated as you surmised. The other possibility is the spring pressure from the top of the rotor is too much. When you set the cap down, you should have a small amount of spring pressure.
Old 07-04-2021, 06:50 PM   #5
GPierce
GPierce's Avatar
The brass dust was from the the worn down brass bushing surrounding the carbon brush. The brass bushing wear can be seen in photo. The rotor and plug contacts tits are untouched. I did have very slight spring back from the cap when I put it on. The hold down springs snapped right on. The distributer body had just been overhauled by a vendor and shaft and bushings were new. I am still leaning toward soft carb or the rotor was not down tight on shaft.
Old 07-05-2021, 03:31 AM   #6
old31
There you go again Chuck with that technical talk "body tits".
old31 is offline   Reply With Quote
Old 07-05-2021, 06:47 PM   #7
1930 coupe
1930 coupe is offline   Reply With Quote
