Old 10-23-2020, 08:54 AM   #1
deuce lover
deuce lover's Avatar
Arrow Banjo pinion removal tool
Found this in a thread on the HAMB.Anyone here tried it this way?
Old 10-23-2020, 08:59 AM   #2
AlexLohmann1
AlexLohmann1's Avatar
Default Re: Banjo pinion removal tool
Yes, several times.
Sent from my SM-G975U using Tapatalk
AlexLohmann1 is offline   Reply With Quote
Old 10-23-2020, 09:58 AM   #3
Will D
Will D's Avatar
I tried it that way with a screw jack as shown in the vern Tardel book and it warped the housing out of round. I ended up buying a cheap hydraulic press and borrowed an exhaust fitting/press tool from local shop to press it out. I then was able to use the press and re shape the housing back round.
Will D is offline   Reply With Quote
Old 10-23-2020, 10:02 AM   #4
AlexLohmann1
I agree.. pressing it from the top is a better option.
Old 10-23-2020, 10:31 AM   #5
deuce lover
Back in '67 I changed out a 4.11 to a 3.54 in a '34 banjo.I used an aluminum drift and hammered it out.Worked but don't want to do it again like that.
Old 10-23-2020, 11:20 AM   #6
rich b
rich b's Avatar
Build a "bridge" thru the housing like in the picture and press it off the pinion without loading the housing. Shouldn't need heat with an adequate press.
A bottle jack on the inside may work; but you don't want your job to be the time it didn't.
Old 10-23-2020, 11:43 AM   #7
bobH
Yes... For my 34, this is the way I did it. If I can find the old picture, will edit/add to this post.
bobH is offline   Reply With Quote
Old 10-23-2020, 01:44 PM   #8
Dave/Green Bay
Check Ken/Alabama post on thread below
https://www.fordbarn.com/forum/showt...ht=ken+alabama
Dave/Green Bay
Dave/Green Bay is offline   Reply With Quote
Old 10-23-2020, 04:18 PM   #9
Angledrive
Angledrive's Avatar
Heat the housing to 200 degrees and it will come out easily.
Angledrive is offline   Reply With Quote
Old 10-23-2020, 07:13 PM   #10
Ideucev8
Yes I have been doing it that way for over 50 years.
Ideucev8 is online now   Reply With Quote
Old 10-23-2020, 07:19 PM   #11
Bored&Stroked
Bored&Stroked's Avatar
This is exactly the way I do it - there is no load on the housing itself - which is the way you want to do it. Also, you're going to need a press anyway to get it back together (easily) - even with the pinion frozen - so might as well buy one if you don't have one.
