02-07-2024, 10:55 PM | #1 |
Columbia install question
On a 33 Tudor, to disconnect the u joint from the rear axle, which is best from the top or underneath the car? Thanks.
Tim Carlig |
02-07-2024, 11:08 PM | #2 |
Re: Columbia install question
02-08-2024, 05:53 PM | #3 | |
Do you mean from the driveshaft?
02-08-2024, 07:31 PM | #4 |
Step two if the Columbia install instructions: “Remove rear axle at universal joint.” Took out the floorboards, easy peasy.
Tim Carlig |
02-08-2024, 09:11 PM | #5 | |
Installed more of them than I could possibly recall. Interesting in that Columbia termed the driveshaft an axle.
02-08-2024, 10:19 PM | #6 |
02-09-2024, 08:51 AM | #7 |
I'm quite certain you are correct.
