10-25-2017, 12:39 PM | #1 |
1947 Super Deluxe Rear-end Ratio
The only numbers I can find on my differential are a 3 and a 2 on the flange where the tork tube connects to the differential. Do you think this means I have a 3.25?
Thanks very much.....Dick. |
10-25-2017, 12:41 PM | #2 |
Re: 1947 Super Deluxe Rear-end Ratio
nope, should be something else stamped in there. the stamps relate to the number of teeth on the ring and pinion gears. I don't think you have a two and a three tooth gear!
10-25-2017, 01:30 PM | #3 |
Probably 3.78 but 3.54 I think was an option. 3.54 was standard in 1946.
10-25-2017, 02:08 PM | #4 |
10-25-2017, 05:10 PM | #5 |
I had a 46, and parted out 3 others, all had 3:78
10-26-2017, 07:55 AM | #6 |
the 3.78's in 1947. Back in 1995 Ford made a 3.31 standard on a F150 with the 5.0 automatic for improved fuel economy. I sold about 5 of them and had probably 4 out of 5 complaining they were shifting out of overdrive on every hill. Learned to spend the $50 to put 3.55's in them. In 1996 I think they went back to 3.55's. The more things change the more they don't! |
