Old 07-18-2016, 10:40 AM   #1
fordfun
fordfun's Avatar
Default Repop steering wheel finish
When I acquired my 1929 Sport Coupe a few years ago it came with a steering wheel cover. The other day I removed the cover and found a great deal of molding flash along the parting line of the wheel. (Hopefully today's replacement wheels are better, as this was definitely an older restoration.)
Initially I tried sanding the flash off, but found that it scuffed the wheel so I ended up skiving it off with a small utility knife. The material I removed was rubber-like, and was easily cut off. I'm wondering whether the scuffed surface can be restored, perhaps by polishing? I already tried rubbing in some silicone, and when that didn't do it I tried some past wax with no improvement. Any thoughts on what to try next?
fordfun is offline   Reply With Quote
Old 07-18-2016, 10:52 AM   #2
Brian T
Brian T's Avatar
Default Re: Repop steering wheel finish
If I remember Snyders have the instructions on refinishing the wheel, look in the steering wheel section.
Nothing can be made foolproof, ---- fools are ingenious bastards.
Brian T is offline   Reply With Quote
Old 07-18-2016, 10:57 AM   #3
700rpm
700rpm's Avatar
Give it a sanding with fine (600 wet or dry, or finer) sandpaper, then some rubbing compound, then finish off with some polish/finish. It's a lot like finishing your paint. Keep in mind the wheel should be a dull finish, not shiny, to be authentic.
Ray Horton, Portland, OR
Old 07-18-2016, 12:26 PM   #4
mlp623
mlp623's Avatar
Here are the instructions from Snyders: http://www.snydersantiqueauto.com/Co...shing-4974.pdf
mlp623 is offline   Reply With Quote
Old 07-18-2016, 12:32 PM   #5
C26Pinelake
give yourself a complete afternoon, it is no easy job, Wayne
C26Pinelake is offline   Reply With Quote
Old 07-18-2016, 08:06 PM   #6
glenn in camino
glenn in camino's Avatar
After sanding off all the flash, I spray mine with rustoleum, Satin black for 29s-31s, and red primer for 28s
glenn in camino is offline   Reply With Quote
Old 07-18-2016, 08:39 PM   #7
msmaron
msmaron's Avatar
Send a message via AIM to msmaron
Your better spraying with dp90
Mark Maron
Ill., Region MARC & MAFCA
MARC JSC Member MAFFI Trustee
National Facebook Admin.
https://www.facebook.com/groups/MARC.group/
A7191-Sport Coupe
29 Roadster
29-Town Sedan
29-Original Special Coupe
msmaron is offline   Reply With Quote
Old 07-19-2016, 09:53 AM   #8
BILL WILLIAMSON
BILL WILLIAMSON's Avatar
A SIMPLE Potato Peeler works good for removing the "flashings"---
Bill Cook
"THE ASSISTANT GURU OF STUFF"
Old 07-19-2016, 12:15 PM   #9
phonconn
I agree sand it down with fine and when the wheel is in the condition you want then get some boot paste from the shoe repair or finer shoe stores. After I restore an original S wheel I put on a heavy coat of the paste wax black shoe polish. NOT the hard stuff but the gooey yogurt consistency stuff. Let it sit for a few weeks to let it soak into the wheel and then just wipe it off without polishing it and you will have the most original finish you can have. Be careful not to polish it or you will have to strip and do it over.
That's how I do the originals so should work on a repop wheel I should think.
phonconn is offline   Reply With Quote
Old 07-19-2016, 09:35 PM   #10
fordfun
fordfun's Avatar
Thanks for all of the valuable suggestions. I'll get busy and put them to work.
Bill W. - great suggestion about the potato peeler. Wish I had thought of it before grabbing the utility knife.
