10-27-2015, 04:43 PM | #1 |
1931 Carburetor Side bowl Drain Valve Seat
Does anyone have a method to lap a 1931 Model A Ford carburetor side bowl casting where the drain valve "petcock" seats? I have an original casting with a new drain valve petcock and it leaks just a little bit.. I was thinking maybe there was a Dremel grinding stone bit, but not sure if one exists.. Checked Steve Pargeter's restoration book and didn't see anything..
10-27-2015, 06:18 PM | #2 |
Re: 1931 Carburetor Side bowl Drain Valve Seat
Is this what you need?
http://www.model-a.org/dremel_911.html |
10-27-2015, 09:04 PM | #3 |
Lap with tooth paste
www.whidbeymodelaclub.com |
10-28-2015, 04:35 PM | #4 |
Thanx for your response.. I have the Dremel 911 grinding stones already and they work great for the fuel line ferrule seat.. The petcock drain valve is smaller and has a point..
10-28-2015, 04:38 PM | #5 |
Good idea toothpaste is gritty.. The only problem is the petcock is threaded once it seats I can't lap it in with a spinning motion.. Do I need to get a another new petcock drain valve, grind the thread's off and make it into a lapping tool?? Thanx for your suggestion
10-28-2015, 04:56 PM | #6 |
10-29-2015, 04:09 PM | #7 |
Thanx for the tip!! I'll try it this weekend
10-30-2015, 09:47 AM | #8 |
Great tips here! Thanks for sharing!
-------------- Drive it like you know how to fix it! DMAFC / OILERS CC-MC |
10-30-2015, 04:04 PM | #9 |
The 911 stone works good on the gas inlet, but is to big for the drain valve on the sidebowl. Clean it up real good and place a drop of silver solder on the tip and then fit to seat.
10-30-2015, 05:41 PM | #10 |
Thanx Carb Guy, briphaeton, Gary WA and Tom Wesenberg.. I agree with Jason in Texas that these are all great tips in this thread!! I have been rebuilding original Model A carburetors (obviously all with no side bowl's)!! for about 20 years as a hobby and thought I had all the carburetor rebuilding problems solved until my Dad gave me his indented firewall 1931 coupe last year (which he finished restoring in 1968 the year I was born).. I don't know how far back the Ford Barn Forum search goes, but was surprised that no one else had this question or problem.. Thanx again, Joe
