Old 08-09-2022, 02:06 PM   #1
Thearne3
Default New design turn signals for Model A?
Hi all,
I've always had turn signals on my Model A's and always annoyed about two things:
1. Most on-column turn signal devices are clunky and ugly. They stand out as 'not from this car'.
2. During the day, when the flasher is not so bright, I often forget to turn off the signal - hence creating a potential hazard: am I turning or not?
I have designed a solution to both these issues and wanted to gauge interest in this community and get your input. The basic concept is to use a 'momentary' SPDT switch - either on the column or where ever the user prefers, plus a magnetic reed switch near the back of the steering wheel. Small magnets are mounted behind the wheel. The 'logic' or brains of the system is a simple programmable board. It will 'know' when you've completed the turn and stop the signal when the reed switches are activated. A failsafe timer would stop the signal after a specified time, say, 20 seconds.
I used CAD software to create a simple, small turn signal for mounting on the steering column with an extension to hold the reed sensor behind the steering wheel. I printed the device using a 3D printer. I'm working on the software now.
Pictures:
The first picture is the prototype. It bolts together with two screws.
The second shows the prototype mounted on the column (the near side screw has not been installed to tighten the clamp)
The third picture shows how unobtrusive the device is. All you see is the switch. I plan to reach through the wheel to tap the switch. You don't have to hold the switch - it just initiates the signal. Note the existing old style switch in the background)
Here are some features:
System is easily compatible with both 6 and 12 volt systems, Pos or Neg ground.
The 'brains' of the system (a box about the size of a pack of cigarettes) will likely be behind the driver's kick panel, but location is flexible.
The wiring from the column to the brains will be a flat ribbon cable on the bottom of the column - again, barely noticeable.
The system can accommodate either dedicated LEDs or integrated with existing parking/running lights - perhaps even including a parking light override (parking light 'on' tells the brain that all turning lights dedicated to parking), which eliminates the need for dual element lights for turning vs running/parking.
Questions for the community:
Is something like this of interest? Would it make turn signal attractive to those who so far have not installed them? Should this be DIY or a kit?
How important is visual/auditory feedback? Indicator lights could be on the switch or mounted elsewhere. So far I haven't designed them into the switch. A buzzer could be connected easily (again, sort of an annoyance, if it can be avoided!)
Any suggestions?
Thanks!
Tom
Thearne3 is offline   Reply With Quote
Old 08-09-2022, 02:31 PM   #2
psimet
psimet's Avatar
Default Re: New design turn signals for Model A?
I was just thinking the other day that with what's available today it should be much easier to do a fairly unobtrusive turn signal setup.
I would love to see something similar to what you have started. I would love to have it be wireless for the switch. Have a battery and show lights to indicate the signal is on and when the battery in it is low. In the rear something that can tap into the wires for the brake light. Mount in the space on the bumpers.
My opinion. I am sure there will be others with better ones.
psimet is offline   Reply With Quote
Old 08-09-2022, 02:40 PM   #3
alexiskai
alexiskai's Avatar
Sounds like you're already moving forward on this for your own use, so I would just say, at this stage, make sure you're documenting everything. Publishing DIY plans won't be too hard when you're finished, and if there's a lot of interest you could move forward with commercialization at that time.
Might be worth investigating packages like the one Brent mentioned in another thread, see how they solve these problems. http://ronsmachineshop.com/Hidden_Turn_Signal_Kits.html
Old 08-09-2022, 03:07 PM   #4
Thearne3
Wireless is certainly an option, though the unit on the column would have to be somewhat larger to accommodate a Bluetooth chip and battery. The wires I plan to use are a flat cable, taped under black electrical tape on the bottom of the column. Wires will always be more reliable than bluetooth!
i like existing systems that use dual brake lights to double as rear turn signals - no need for between the bumper lights. That's how my existing (old) turn signals work. However, the core system can be set up either way.
Thanks for your input! I'll work on integrating a light into the switch...however, the base of the switch is obscured by the Spark advance plate, so there's a trade-off.
Old 08-09-2022, 03:11 PM   #5
Thearne3
I'm not sure how 'smart' that system is. It's nice that it 'hides' the turn signal switch (which I could do as well, but prefer a 'traditional' switch placement). It may be that the sensor bracket alone would be of interest in any system that could use the input.
Thanks!
Old 08-09-2022, 03:18 PM   #6
alexiskai
alexiskai's Avatar
Not smart necessarily, but it does have the benefit of having sold some units to satisfied customers, so chalk it up to market research: how does the control unit mount? How loud is the buzzer? Etc.
You could post a poll here, ask people to vote for any features they'd be willing to pay more money for in a turn signal product.
Old 08-09-2022, 04:16 PM   #7
Y-Blockhead
Y-Blockhead's Avatar
A lot of folks have the Logolites Turn Signals and i have not heard any complaints.
I made my own hidden turn signal system using a dpdt switch hidden under the dash rail and amber bulbs in the HL reflectors.. It is only as smart as the operator (me).
Two things I don't like is the big switch on the column and the lights between the bumper bars.
There are many threads on turn signals.
Any suggestions?
Thanks!
Tom
I think there may be some interest to those that would like to have a kit and customize it to their wants and needs.
Old 08-09-2022, 04:39 PM   #8
john in illinois
john in illinois's Avatar
I have an electro tech system on my roadster. It is self cancelling,has internal flasher and works with any bulb ,led or regular. 6 or 12. Unit is under dash.all electronic.
I like it and have had good luck with it. This might help you see what is out there and give you some ideas.
http://www.turnswitch.com/Turnsignal.htm
John
Welcome each day
john in illinois is offline   Reply With Quote
Old 08-09-2022, 07:11 PM   #9
nkaminar
nkaminar's Avatar
I have a certain amount of nostalgia for the clunky switch. This is what was available back in the day when you wanted to add turn signals to your pre 1955 car. The only difference is the little rubber wheel that is missing on the present production. The wheel turned against the steering wheel and would cancel the turn indicators after you made your turn.
Old 08-10-2022, 10:07 AM   #10
BRENT in 10-uh-C
BRENT in 10-uh-C's Avatar
Thanks!
I think this is a preference thing. Yours will work fine. Its all in what you get used to, and sometimes with a spark lever and oversized steering wheel, it can get busy in a hurry by the time a turn signal lever is added to the mix.
As for the sensor, I personally like to "hear" that I left the turn signal on. With the unit I suggested, I find that on closed cars, a piece of tape over the turn signal buzzer tends to mute it enough to still be effective but not muffle it enough that it cannot be heard. On open cars with the controller behind the kick panel, it is plenty lout to hear it while driving. In an open car, the amount of daylight entering the vehicle might cause the sensor light to not be bright enough.
Ohh, you mentioned that you 3 printed that. What machine did you use? We have a Makergear M2 that we like but we are finding ourselves needing a larger and faster machine for making 'stuff', so an upgrade is likely in our future. One such 'stuff' is we have begun making sheetmetal dies for small runs of sheetmetal repairs on vehicles we are restoring. What a game changer!! For example, we are working on a 1929 Coupe (45A) that we need to make some replacement sheetmetal pieces for the ¼-window area that is rusted away. We just drew it up in SolidWorks and just printed out dies that we can use either in an arbor press, or in a Pullmax to make the correctly shaped replacement pieces. Sorry to hi-jack your thread talking about nonsense, but I definitely find a printer is a great way to prototype for things like your signal switch.
BRENT in 10-uh-C
www.model-a-ford.com
...(...Finally Updated!! )
Old 08-10-2022, 10:26 AM   #11
Thearne3
John
Thanks, John. That is a goldmine for options! I think they’re using a mercury switch to detect ‘lean’ or at least momentum for a turn - very clever. It’s also more universal for older cars. My approach to cancelation depends on the Model A steering wheel configuration.
Old 08-10-2022, 10:34 AM   #12
Thearne3
Perhaps a separate thread for uses of 3d printing? I use Fusion 360 for modeling and simple Anycubic 3D for printing - will print up to 10” cubic area. So far I’ve used it for three things for the A: the ‘Yoke’ piece in the vacuum wiper, bumper holder for LED signal lights (the ones sold by venders are WAY over priced!), and now this project.
Old 08-10-2022, 10:35 AM   #13
Thearne3
If I had the device you describe, I probably wouldn’t have gone down this road!
T
Old 08-10-2022, 10:39 AM   #14
Thearne3
Thanks! Didn’t mean to demean that system at all - all have pluses and minuses. I was using ‘smart’ as in smart phone - having a processor that can be programmed for new inputs.
Once I have something that I like working, I think a poll is a great idea!
T
Old 08-10-2022, 10:53 AM   #15
psimet
psimet's Avatar
I'd love it if there was a thread for 3D print models for devices for Model A's. Just a general thread where everyone could drop in whatever models they came up with or at least link to where they are stored.
Old 08-10-2022, 02:08 PM   #16
GeneBob
In answer to the OP's questions, I like where you are going with this. A smaller box with self canceling and beeper and/or lights added would be very nice. Just to make it more difficult for you; have you considered the 4-way function for hazard lights?
GeneBob is offline   Reply With Quote
Old 08-10-2022, 05:12 PM   #17
Thearne3
Definitely! This will be part of the code, eg, holding switch up (or down) for 5 plus seconds initiates hazard lights. Tapping again cancels. Similarly, lane change would be a tap, full turn might be short hold (1/2 sec?). It’s all programmable. Will have to experiment with timing!
Old 08-10-2022, 05:47 PM   #18
panhead_pete
panhead_pete's Avatar
I have the logolites and love the buzzer and the way the control is somewhat hidden. Super simple to install too with one wire per signal light. If you could include a buzzer that would be a plus in my books.
I just really dislike the way the logolites look though and after chatting with them there isnt other options available using their tech. Please set yours up so that it can use any LED turn signals.
Looking for an unrestored 33 34 3W or 5W coupe.
Thanks
panhead_pete is offline   Reply With Quote
Old 08-12-2022, 05:36 PM   #19
CarlG
CarlG's Avatar
I'm rather partial to the Signalstat 900, I have no problem in remembering to turn it off.
Alaskan A's
Model A Ford Club of America
Model A Restorers Club
Mullins Owner's Club
Old 08-12-2022, 07:31 PM   #20
Cape Codder
Cape Codder's Avatar
Other than the buzzer a small light can be installed in the second screw from left o drivers side. I saw this some time ago where the screw was drilled right in the center and than a SMALL LED was installed! So than there would be no need for a buzzer. Of course after some searching I was unable to find the thread! Sorry......
I don't care if the "A" Starts BUT sure WANT IT TO STOP!
Cape Codder is offline   Reply With Quote
