Old 02-25-2021, 04:01 PM   #1
31slant
Default Interior some light
How do you feel about two in a four door? And switch under dash or door activated?
31slant is offline   Reply With Quote
Old 02-25-2021, 05:37 PM   #2
Mike Peters
Mike Peters's Avatar
Default Re: Interior some light
It's your car, and you can't have too much light.
Mike Peters is offline   Reply With Quote
Old 02-25-2021, 06:46 PM   #3
Oldbluoval
Oldbluoval's Avatar
Ditto what mike says
Oldbluoval is offline   Reply With Quote
Old 02-26-2021, 06:25 AM   #4
shew01
shew01's Avatar
I keep a magnetic light attached to the underside of the gas tank. Simple and works great.
Ullman Devices RT2 LT Rotating Work Light - Magnetic Site Light with 24 LED Bulbs, Swivel Head. Site Lighting Supplies - RT2-LT https://smile.amazon.com/dp/B003Y3VA...ing=UTF8&psc=1
shew01 is offline   Reply With Quote
Old 02-26-2021, 07:34 AM   #5
Big hammer
Soooooo what are you doing in your car that you need more lighting ? It's more fun feeling around in the dark! My L 31 Tudor originally didn't come a light but some one before me installed a light in the headliner just behind the drivers head. The light was turned on by door switches which was ok but I changed it to a dash switch, it can be turned on going down the road without opening a door!
get a bigger hammer tap done
Old 02-26-2021, 09:33 AM   #6
Bob Bidonde
Bob Bidonde's Avatar
I had this same thought because the dome light in my Victoria is over the rear window and very much inadequate in lumens. I converted the dome light in my Victoria to LEDs, but this was futile as I could not get enough of them into the housing to make a significant difference.
Bob Bidonde
Old 02-27-2021, 05:45 AM   #7
31slant
Ya the body i have has the original above the rear window was thinking adding one above the windshield or in the head liner. I like the switch in the dash idea thanks.
Thread Tools
Display Modes
