Old 02-24-2021, 11:46 AM   #21
hombres ruin
hombres ruin's Avatar
Default Re: Whirring noise .. from I don’t know where
I checked the fan and it’s fine. The fan hub bolts are solid tight as well
"I have built my organisation on fear"..Al Capone.
hombres ruin is offline   Reply With Quote
Old 02-24-2021, 11:46 AM   #22
hombres ruin
I believe so. Not sure tho
Old 02-24-2021, 09:02 PM   #23
Brendan
Brendan's Avatar
Originally Posted by john in illinois View Post
Long shot,I once had a starter bendix contact the ring gear intermitantly
New bendix fixed it. It made clics and whirrs. Took a while to find it.
John
yup i had that same one, the Bendix was worn out
If it would have been a snake it would have bit ya!
i can't spell my way out of a paper bag!
Brendan is offline   Reply With Quote
Old 02-25-2021, 10:01 AM   #24
Ken hash
Ken hash's Avatar
Post number 11 is worth a look. The starter has a bendix spring on the end of it. The spring has two bolts holding it to the shaft of the starter. If the spring is weak or if the bolts come loose it can cause the ring gear on the flywheel to rub against it and it will make a whirling kind of sound. Good luck
Ken hash is offline   Reply With Quote
Old 02-26-2021, 11:19 AM   #25
hombres ruin
Well I checked for a vacuum leak and there wasn’t one. I will have to get it up on a rack in the next week to check the bendix and flywheel
Old 02-26-2021, 02:20 PM   #26
drolston
drolston's Avatar
Can you get to a steep road or driveway. If the noise is less facing uphill than downhill, that would point to the bendix, which while slanted uphill would tend to stay off of touching the flywheel.
Old 02-27-2021, 10:57 AM   #27
deuce_roadster
deuce_roadster's Avatar
I have known of a vacuum leak causing the vacuum break piston to flutter. Check the vacuum line to the distributor at both ends.
Old 03-01-2021, 02:36 PM   #28
hombres ruin
Hey deuce I checked the line and it’s all intact, no splits , fraying or holes
