Old 02-23-2021, 10:09 PM   #81
GB SISSON
GB SISSON's Avatar
Default Re: Australian 1940-1941 Ford Open Cab Pick-Ups
Originally Posted by mercman from oz View Post
This time around, we have a early photo of a 1941 Ford Open-Cab Truck with Marmon- Herrington Four Wheel Drive.
And just when I thought I'd seen my end all 4wd ford truck comes this.... Holy Crap.
Owner/Operator of 'Jailbar Ranch' on the side of Mt. Pickett. Current stable consists of 1946 1/2 ton pickup turned woodie wagon with FH V8, 1947 Tonner Pickup (red) mostly stock with exception of a cummins 6at turbo diesel, 1946 Tonner Pickup (green) with 226 cu in 6 cyl flathead, 1979 Toyota landcruiser wagon, completely encased in 1947 Ford Jailbar sheet metal. Ok, cornbinder rear fenders..... 'Rusty ol' floorboards, hot on their feet' (Alan Jackson)
Old 02-25-2021, 05:18 PM   #82
mercman from oz
mercman from oz's Avatar
Here was have a photo of another 1940/1941 Ford Open-Cab Truck taken many years ago.
This one has the Marmon-Harrington Four Wheel Drive conversion. I can't tell whether it is a 1940 or 1941 model?
What is unusual is that this Open-Cab Ford Truck is Left Hand Drive?
Old 02-28-2021, 10:00 PM   #83
mercman from oz
I know that I am getting slightly off track here, but I thought that I would share this picture of an Australian 1941 Ford Deluxe Ute. This Ute was in a Brisbane Wrecking Yard of yesteryear.
Check out the Waterfall Trim on each side of the centre strip on the Hood. That is how you tell that this Ute is a 1941 model and not a 1940 model.
In the USA, you released a similar vehicle with the Waterfall Trim on each side the Hood, but the only body style available in the USA for this 1941 model was the Sedan Delivery.
On this Ute, the photo of which was taken decades back shows a Hatch on the Roof. It may have been an ex Military model, or this modification could have been added later?
What is unusual is that these models have Ford Deluxe on each side of the Hood. all very unusual.
Old 02-28-2021, 10:05 PM   #84
mercman from oz
Page from the Ford Australia Identification Manual for the 1941 Model "11C" Ford Deluxe Coupe Utility.
Notice that it lists this Ute as a Ford Deluxe model.
Old 03-02-2021, 01:30 AM   #85
mercman from oz
For 1941 in Australia, Ford offered locally two different Utes. I showed the one that had the carry-over body of the 1939-1940 models in Post 83. This is the second type of Ute that was offered in Australia.
I took this photo of an Australian 1941 Ford Ute wasting away in a country wrecking yard many years ago. The Front Clip is sitting in the back ready for someone to come along and save it.
Unfortunately, this yard was closed to make the land available for houses, so it is unknown if this Ute was saved?
These Utes were made by cutting down 1941 Ford Sedans. You can see this by the "C" Pillar that lacks any style. This style of 1941 Ford Ute was used by the Military
Old 03-02-2021, 01:37 AM   #86
mercman from oz
Page from the Ford Australia Identification Manual showing both the 1941 Model "11C" Ford Deluxe Coupe Utility and the other 1941 "11A" models. Very few 1941 Ford Sedans were sold in Australia. I can only recall seeing one back in the day when you saw lots of old Fords on the road as everyday cars.
Old 03-02-2021, 08:55 PM   #87
mercman from oz
Australian 1941 Ford Ute. This is how all these 1941 Ford Utes looked.
It seems that they made dozens of them, all made from cut-down 1941 Ford Sedans.
It is parked next to a 1940 Ford Military Truck. Photos taken in 1996.
Old 03-02-2021, 09:51 PM   #88
alanwoodieman
you have to quit showing me these pictures! so interesting. I have a book on WW2 German ford trucks, I want them all. the 40/41 is a 41--flat dash not raised in the center
alanwoodieman is online now   Reply With Quote
Old 03-02-2021, 11:15 PM   #89
cas3
more good stuff Mercman! the hatch in the roof may have been military, but usually the roof gun locations were a heavy steel round thing that actually had a trolley running around the top so the gun could swing around 360*. ring mounts they were called. sure would have been fun visiting those yards years ago. thanks for posting
cas3 is online now   Reply With Quote
Old 03-03-2021, 09:35 PM   #90
mercman from oz
Another Australian 1941 Ford Ute. This model was made from Fordor Sedans and there are literally dozens and dozens of these unique to Australian 1941 Ford Utes.
Old 03-03-2021, 10:22 PM   #91
Will D
Will D's Avatar
My brain finally got over the oddity of the Ute style, until I saw that bumper. From typically seeing North American style models, it seems like somethings not quite right with the dimensions and dissimilar body features when viewing a Ute. I like the concept and versatility of them, especially the open cab models. Interesting what catches on in different parts of the world, and how much a little detail, like a bumper can change the look of a vehicle. If that was a face it looks like quite the overbite. Call me weird but I'm actually more crazy
Is it "a Ute" or "an Ute" ??
Sometimes, ingenuity gets in the way of sense and sanity.
Will D is offline   Reply With Quote
Old 03-04-2021, 04:17 AM   #92
mercman from oz
I am with you Will regarding that Bumper.
Here is a front on shot of the same vehicle, the Australian 1941 Ford Ute
I don't believe that the front Bumper is correct for these Utes?
It should have more shape and not a heavy piece of steel.
Also, the Grilles on these Utes should not be Chrome Plated.
The Grilles are actually pressed metal, not Diecast on these 1941 Ford Utes.
Old 03-04-2021, 04:26 AM   #93
mercman from oz
While the regular production 1941 Fords had Diecast Grilles, it was different for these Military 1941 Ford Utes.
Check the above pictures and you can see the Pressed Steel outer Grille Pieces, correct for these commercial 1941 Ford Utes.
Old 03-04-2021, 06:46 PM   #94
mercman from oz
Check out this 1941 Ford Ute and the price, $150. Seems absolutely complete.
The "good old days" when these old Fords were affordable.
Wonder if it was saved?
Old 03-05-2021, 01:32 PM   #95
GB SISSON
GB SISSON's Avatar
Thought I'd post my latest revision on my project because I have been heavily influenced by this thread. Not to hijack so if interested it's the thread '40 ford front fenders. Couldn't make the 40s work. That 38 military 4x4 works with parts I have laying around here.
Old 03-05-2021, 04:46 PM   #96
mercman from oz
That is one interesting concept?
Old 03-05-2021, 06:47 PM   #97
51504bat
51504bat's Avatar
Nice attention to detail. Even shows the correct 6 lug Toyota Land Cruiser wheels.
51504bat is online now   Reply With Quote
Old 03-05-2021, 07:10 PM   #98
cas3
its gonna be a good one GB !
Old 03-05-2021, 11:19 PM   #99
GB SISSON
GB SISSON's Avatar
Thanks. I even have a set of 16" six lug factory toyota split rims. Non USA of course.
Old 03-05-2021, 11:49 PM   #100
51504bat
51504bat's Avatar
This thread on the FTE is about a MH panel donated to the Australian Salvation Army by the US Salvation Army. Not an open cab but still interesting. IMO.
https://www.ford-trucks.com/forums/1...errington.html
