04-29-2018, 05:54 PM | #1 |
1940 Ford 12 volt battery
Converting my 40 Ford to 12 volt and looking for a battery with the same dimensions as a 6 volt so I can use the stock battery tray and hold down. Napa store couldn't come up with a match. Any ideas? Thanks.
04-29-2018, 07:12 PM | #2 |
Re: 1940 Ford 12 volt battery
Group 24
Works good Lasts long time |
04-30-2018, 08:22 AM | #3 |
Here's a photo of the Group 24 Walmart battery I use. Cost about $100. 5 year guarantee. You have to turn the battery so the (-) terminal is near the firewall.
I used a copper sleeve on the negative terminal post to make the cable fit tight. Works fine. Removed labels for plain look. PS: I know that my battery disconnect is on the "wrong" post but, it works Last edited by 19Fordy; 04-30-2018 at 08:29 AM. |
04-30-2018, 08:31 AM | #4 |
RAF....is it a hassle to convert ? What's the toughest part of doing it ?
Thx....Mike |
04-30-2018, 03:46 PM | #5 |
Not that hard to change over, had my generator and starter changed to 12 volt, added 12 volt regulator, coil, light bulbs, and voltage reducers for gauges. There is a lot of information on the changeover if you search the internet.
04-30-2018, 04:23 PM | #6 |
https://www.fordbarn.com/forum/showthread.php?t=238536 |
05-01-2018, 01:53 AM | #7 |
Thx
