Old 10-12-2021, 08:47 PM   #1
callbald
callbald's Avatar
Default 64 Galaxie 289 water pump pulley
I am converting from manual to Borgeson P/S. Do I need to replace the water pump pulley from 1 to 2 belt grooves. to match the new crank 2 groove pulley.
Original 1st crank groove drives the generator and water pump.
The second crank pulley would idle off the water pump and drive the P/S pump.
Or can I go directly from the crank pulley to the P/S pulley and leave the water pump pulley as is.
callbald is offline   Reply With Quote
Old 10-12-2021, 08:54 PM   #2
craig
Default Re: 64 Galaxie 289 water pump pulley
I'd leave the w/p as is. My original set up is that way
craig is offline   Reply With Quote
Thread Tools
Display Modes
