Old 10-11-2021, 03:53 PM   #21
KULTULZ
KULTULZ's Avatar
Thumbs up Re: 56 instrument cluster module holes?
Originally Posted by 56sedandelivery View Post
there does not appear to be any casing numbers on either one. The one with the holes in it on the back lower right side there is: Ks-2 49204. Those are the only number on them. The one without the holes has no numbers at all.
!!! Thanx !!!
- WHY IS IT ... -
... that everything you buy in the grocery store is either wrapped in or contained in plastic but the government doesn't want you to carry it out in a plastic bag?
WONDERING IN W(BY GOD)V ...
DIAGNOSED CDO - (OCD In Correct Alphabetical Order)
KULTULZ is offline   Reply With Quote
Old 10-11-2021, 07:00 PM   #22
raceron1120
raceron1120's Avatar
Default Re: 56 instrument cluster module holes?
Originally Posted by KULTULZ View Post
THANX for the info and speaking loudly so I could here you ...
My wife says I can't hear (selective deafness??) so I type a bit more loudly than usual anymore.
raceron1120 is offline   Reply With Quote
Old 10-11-2021, 07:21 PM   #23
dmsfrr
dmsfrr's Avatar
mercman -
That is the 57 BIRD INSTRUMENT CLUSTER ...
Side-by-side photos of the main differences, in addition to the engine-turned aluminum faceplate.
The opening at the bottom center of the '56 sedan style dash is more angular than the half-circle of the '57 T-Bird version.
The T-Bird speedometer shows 140 mph, the others are 120.
The full-sized '57 Fords had a different style dashboard & speedometer.
dmsfrr is offline   Reply With Quote
Old 10-11-2021, 11:26 PM   #24
KULTULZ
KULTULZ's Avatar
!!! AHA !!!
That explains the differing part numbers.
!!! THANX !!!
- WHY IS IT ... -
Old 10-11-2021, 11:57 PM   #25
dmsfrr
dmsfrr's Avatar
!!! THANX !!!
The Oil and Gen lights are also in a different location.
Old 10-12-2021, 08:19 AM   #26
KULTULZ
KULTULZ's Avatar
Question Re: 56 instrument cluster module holes?
... hmmpf ...
Just where are the warning lamps on the 56 FORD? Does it have them? I see where it uses gauges.
Old 10-12-2021, 08:22 AM   #27
KULTULZ
KULTULZ's Avatar
I admire a man that posts so authoritatively ...
... awful big word for a 3rd grade dropout ...
- WHY IS IT ... -
Old 10-12-2021, 10:48 AM   #28
dmsfrr
dmsfrr's Avatar
Lower left of the dash cluster, where the '57 Birds put the tachometer.
File Type: jpg '56 ford_fairlane_sunliner_convertible - Oil & Gen c2.jpg (63.1 KB, 7 views)
Old 10-12-2021, 12:37 PM   #29
KULTULZ
KULTULZ's Avatar
CRS and CSS is catching up with me.
THANX AGAIN!
- WHY IS IT ... -
