Old 07-01-2021, 04:51 PM   #1
hardtimes
hardtimes's Avatar
Default Oil pump id ?
Anyone know if this is A, B pump ? Thanks
hardtimes is offline   Reply With Quote
Old 07-01-2021, 04:58 PM   #2
tinkirk
tinkirk's Avatar
Default Re: Oil pump id ?
Kind of looks like the one that i put installed in brother in-laws 30 roadster
tinkirk is offline   Reply With Quote
Old 07-01-2021, 06:20 PM   #3
johnneilson
Cee
As Carroll Smith wrote; All Failures are Human in Origin.
johnneilson is offline   Reply With Quote
Old 07-02-2021, 07:01 AM   #4
Bob Bidonde
Bob Bidonde's Avatar
It is a Model "A" pump. The Model "A" & "B" pumps are fit, form and functionally interchangeable. There is a minute difference. The oil exit hole in the Model "B" pump is rectangular, but it is round in the Model "A's" pump.
Bob Bidonde
Old 07-02-2021, 12:44 PM   #5
johnneilson
Bob,
you are correct, I believe it is an early "A" pump.
more than likely the housing has only a 9/16" bore instead of the later 5/8"
It can be modified to increase the output if necessary, just have to look at the application.
John
Old 07-02-2021, 02:40 PM   #6
dave hummell
Don't forget the B oil pump shaft is cut down to I think .410 diameter for more flow.
dave hummell is offline   Reply With Quote
