Old 08-02-2013, 03:29 PM   #1
wspiker
wspiker's Avatar
Default 1940 Ford Truck handle
I would like to unlock my truck handle latch and than remove the key. Currently my Bob Drake handle will not allow me to do this. Can someone please advise what alteration I can make to the key so it can be removed from the latch after unlocking the latch?
Thanks,
Daryl
wspiker is offline   Reply With Quote
Old 08-02-2013, 03:48 PM   #2
40cpe
40cpe's Avatar
Default Re: 1940 Ford Truck handle
I think you are talking about a trunk lock. The best method I have found is to grind the key handle end down so that you can close the keyhole cover over it. If you want it locked just remove the key
40cpe is offline   Reply With Quote
Old 08-02-2013, 05:51 PM   #3
cmbrucew
cmbrucew's Avatar
I got my Drake handle from Mac's, but the key comes out, locked or unlocked.
Try your favorite lube and work it back and forth, it should come out.
Bruce
Works good
Lasts long time
cmbrucew is offline   Reply With Quote
Old 08-02-2013, 06:06 PM   #4
wspiker
wspiker's Avatar
Thanks for letting me know the options, guys. Thank you, thank you. I'll give them a try......
Old 08-02-2013, 08:52 PM   #5
40cpe
40cpe's Avatar
Bruce
Works good
Lasts long time
My handle is a Drake from the early '90s. Key won't come out unlocked.
Old 08-02-2013, 09:41 PM   #6
okiedokie
okiedokie's Avatar
Key wont come out of my Drake handle. Wonder if Bruce's is a Vintique or ?? I would gladly change mine.
okiedokie is offline   Reply With Quote
Old 08-02-2013, 10:14 PM   #7
cmbrucew
cmbrucew's Avatar
Sorry my bad.
The handle I bought was 11A-7043511 for 41 to 48.
Bruce
Works good
Lasts long time
Old 08-03-2013, 09:30 AM   #8
Gary in La.
Gary in La.'s Avatar
The key does not come out on these handles and cylinders when in the unlocked position as original.
Gary in La. is offline   Reply With Quote
Old 08-03-2013, 10:09 AM   #9
296 V8
Strange
The Drake handle I put one my dads 40 can be unlocked w key out
Id think a old / good lock smith could make it happen blindfolded
296 V8 is offline   Reply With Quote
Old 08-03-2013, 01:34 PM   #10
push_rod
push_rod's Avatar
Originally Posted by 296 V8 View Post
Strange
Considering the way the lock cylinder is constructed, I doubt that any locksmith could modify it so you could remove the key when the cylinder is in the unlocked position (Unless he removed all of the internal slugs; then you could remove the key no matter what position the cylinder is in... except that then anyone with a pocket knife or small screwdriver could also unlock your trunk!).
The original 1940 Ford trunk lock cylinder has to have the key inserted and then rotated 180 degrees for the handle to unlock. The key can not be removed without rotating it back 180 degrees to the locked position.
Bob Drake's reproduction 1940 Ford Trunk handles differ from original in that you only have to rotate the key 90 degrees in order to unlock the trunk, but once again you must rotate the key back to the locked position before you can remove it.
Best regards,
push_rod
push_rod is offline   Reply With Quote
Old 08-03-2013, 06:48 PM   #11
wspiker
wspiker's Avatar
A little over a year ago someone on the Ford Barn did this to his '40. He said he got tired of unlocking the truck to get the lawn chairs out! He said it was pretty 'straight forward' and he figured it out. Hopefully, he will 'chime in' and share with us?
