Old 01-06-2018, 04:56 PM   #1
PO51
PO51's Avatar
Default Frame welting
Getting ready to put the welting on my 29 Business Coupe, can someone tell me where it starts and ends on the frame?
PO51 is offline   Reply With Quote
Old 01-06-2018, 05:02 PM   #2
Steve Plucker
Default Re: Frame welting
Here you go:
http://www.plucks329s.org/pdf/studie...EAKARTICLE.pdf
Pluck
Old 01-06-2018, 08:54 PM   #3
PO51
PO51's Avatar
Still not clear, on a 29 Coupe, where on the frame does it start and where on the frame does it stop?
Old 01-06-2018, 09:39 PM   #4
Steve Plucker
Are you looking for the purist way or the non-purist way?
Pluck
Old 01-06-2018, 10:25 PM   #5
PO51
PO51's Avatar
Forget it! I’m so tired of not being able to get a simple answer here!
Old 01-06-2018, 10:48 PM   #6
Russ/40
Russ/40's Avatar
Very front of the frame horns to the end of the splash shields.
Old 01-06-2018, 11:23 PM   #7
PO51
PO51's Avatar
Thanks
Old 01-08-2018, 12:31 AM   #8
Tom Wesenberg
Tom Wesenberg's Avatar
Tape the ends and let it set for a day before punching the holes. I found it tends to shrink a little after it's unrolled.
Old 01-08-2018, 12:48 PM   #9
BillCNC
BillCNC's Avatar
While mine is not a coupe, my 31 Tudor's welting runs from the front to rear, ... Full length of the frame. I'm going to be adding mine soon as well as I just finished making her a rolling chassis again.
I have the self adhesive backed version. That's what's on there now and from what I have read, ... it makes the job 10x easier.
Regards
Bill
BillCNC is offline   Reply With Quote
Old 01-08-2018, 01:25 PM   #10
BRENT in 10-uh-C
BRENT in 10-uh-C's Avatar
I have the self adhesive backed version. Thant's what's on there now and from what I have read, ... it makes the job 10x easier.
Regards
Bill
Bill your car, -your rules, but originally the anti-squeak only was under pieces of sheetmetal that were bolted directly to the frame. The body used wood (-with rubber sheeting tacked to it) to prevent squeaks. There is not anything beneficial to running the welting the full length of the frame.
BRENT in 10-uh-C
www.model-a-ford.com
...(...Finally Updated!! )
Old 01-08-2018, 01:35 PM   #11
BillCNC
BillCNC's Avatar
Brent,
I understand that.
I figured since they give you 20", ... enough for both frame rails to be covered their entire length, why not.
Regards
Bill
