08-28-2021, 07:58 PM | #1 |
1950 Ford F7, carb leaking fuel
Hi Guys.
My Dad is working on a 1950 Ford F7 truck. It was a fire truck. We put on a new fuel pump (NAPA). When we start the truck, after about 20 seconds fuel will start to drip from the intake of the carb. The carb intake faces the firewall. I have tried setting the float lower. When I take the top off the carb now, the float bowl is not full to the top. The engine is a flat head V8. The governor is disconnected. The butterfly below the carb is set open. Also can someone tell me the make/model of the carb? The only info on it is on the diaphragm that says "Holley Centri-vac Governor" Thanks for your help. |
08-28-2021, 07:59 PM | #2 | |
Re: 1950 Ford F7, carb leaking fuel
08-28-2021, 10:10 PM | #3 |
NAPA has went off shore along with other big box stores, try one of the rebuilders on the barn. They will know what correct pressure is. Same on Carb.
08-29-2021, 08:09 AM | #4 |
Wow you bought a new fuel pump from Napa? Went there for a 7 inch sealed beam these new kids thought I'm a alien, no clue they never saw a Jeep? sounds like this fuel pump is over pressuring the float needle valve. Yes its a Holley forget about the governor nothing to with this problem. What is butterfly below is open mean? should be closed for idle. I'm still amazed a pump from Napa. I needed one they are out there if you take out a loan. So i bought a 6vt Bendix electric '3lb pressure' end of that. How is the needle valve? if good still think too much fuel pressure. Also push comes to shove a 4 bolt Rochester will go right on there. I can't remember the model or number till I go to the shop we have all the books on those. sam
08-29-2021, 10:04 AM | #5 |
I believe "sciala" on this forum has a lot of experience with these old 4 bolt Holley's.
"big job" is right; a small base Rochester 2G will bolt directly to your manifold. If you mount it backwards, the throttle linkage and fuel line will almost fall into place. The manual choke will on the wrong side, but I always use an automatic choke on these as that lines up as well. Since this is a big truck, this may not be applicable, but it works on cars. Although the carb does bolt to the manifold, the throttle bores in the manifold are quite a bit smaller, so it should be bored out. I have a jig and broach for that particular process. |
08-29-2021, 10:29 AM | #6 |
The power valve system is integral to the top cover and also has to be sealed at the vacuum port on the interface of it and the throttle body for it to work properly. A fuel pump can sometimes overpower the float valve if the pressure is much more than 2 to 3 psi so a pump pressure check might be in order. If it's too high, a fuel pressure regulator may be in order. |
08-29-2021, 10:43 AM | #7 |
The official Holley model number is 885FFG. The G meaning governor. On Pass cars it was an 885FF.
Everything Rotorwrench said is good info. Sal |
08-29-2021, 01:03 PM | #8 |
Reply to Big Job.
Yes, the NAPA had a fuel pump sitting on the shelf. You could be right, I do not know the fuel pressure. The carb sits on a spacer that has butter flys below the carb main butter flys. I believe it is part of the governor. |
08-29-2021, 05:08 PM | #9 |
Maybe I'm missing something here, but the governor is all contained on the carburetor with the Holley Centri-Vac governor. I would guess that the spacer may have been added under the carb, or maybe part of the original system, but seems odd to me. I have some governor experience, but not with this application.
Sal |
08-30-2021, 04:54 AM | #10 |
Sals right What you have is a velocity type governor That was added Could be something for fire service; could be the Centri vac system failed, who knows. The original gov system is all controlled by vacuum in the bottom of the distrbutor. The faster it spins 'dist.' by centrifugal force a valve opens admitting vacuum to that big
diaphragm on the carb. that starts to close the carb. throttle plates. To set RPMs has to be done in the distributor A real bear to work on. sam I'll never know why they didn't put distributor up front like its little 8BA brother? |
08-30-2021, 10:26 AM | #11 |
The engineers at Ford must have had some reason why they designed the 337 engine the way they did but it usually boils down to convenience for one reason or another. The trucks may have also needed vacuum for the brake system on those Big Job trucks. Most big trucks has some form of throttle governor to keep the operator from destroying the engine. Some are more complicated than others. Holly made the distributors as a spark control system to work with their carburetors in the 8BA era and on into the Y-block era as well plus the need for truck governors. This also solved Fords design needs pretty well.
08-30-2021, 02:28 PM | #12 | |
08-31-2021, 05:01 AM | #13 | |
Not quite Kyrvyn what you have is now THE governor the real original most likely failed the easy fix is install this type. This type requires no plumbing easy to set rpms with a simple allen wrench. My big bet it will say "HOOF" on it who was a major mfg. of this type. This summer we installed one on a hydroseeder Ford engine. Very common on wood chippers water pumps, generators . sam Last edited by big job; 08-31-2021 at 05:09 AM. |
08-31-2021, 08:29 AM | #14 | |
Yes true but when it comes time for points cond. and such ya need step ladders a Magnet, glasses likely some young blood that can see it. And yes these trucks have a two piece distributor with a clamp whoops there goes that clamp nut that's gone. bottom line is 'I' like 337s got F8 tractor full air road worthy 3 engines in stock, one with 9,000 miles in the shop. So write this up as LOL wish I was 40 yrs younger that's LOL...sam |
08-31-2021, 11:30 AM | #15 |
"Designed" for convenience of manufacture maybe but definitely not for convenience of service. Same goes for the Y-blocks both large and small. COEs are real fun but they sure look good.
09-13-2021, 05:41 PM | #16 | |
Where is a good place to buy a carb kit?? Where can I buy a fuel pressure regulator to plumb between fuel pump and carb? |
09-14-2021, 05:46 AM | #17 |
Pressure regulator I'd say any local parts store or they can get one. Carb kits pop on
ebay but for a car which will work you mainly need new gaskets, pump cleaning.. As far as a kit with a governor is a tough call, besides all you will get is the rubber diaphram. Then I had a flash back = we had a Marmon transit bus around a 1960 V8 332 Y block and had that carb then I remember a White WC dump truck had that carb. Maybe others used those too its a start to research. Try Kanter Auto on line sam |
09-14-2021, 07:37 AM | #18 |
New kit on ebay now compatable with todays junk gas $59.95
