09-28-2020, 05:14 AM | #1 |
Dash Light Bulb Changeout
So simple yet so complex! How do you change out the bulb in a Model A Dashlight?
09-28-2020, 06:50 AM | #2 |
Re: Dash Light Bulb Changeout
Twist and pull the cover off. There's a groove that lines up with a bump on the cover letting it pull off easily. Worst case force it off, won't damage it, really.
09-28-2020, 08:26 AM | #3 |
Put a diode bulb in the light instead on an incandescent bulb.
Bob Bidonde |
09-28-2020, 08:49 AM | #4 |
09-28-2020, 10:17 AM | #5 |
What year?
09-28-2020, 10:50 AM | #6 |
Not sure, but maybe others can confirm: would this bulb work? "81 LED Bulb 6 Volt Positive Chassis or Negative Chassis Miniature bulb. The maxium bulb length is 1.24 inches and the maxium diameter is is .75 inches. This will fit the small size of a #81 light bulb. BA15S single contact. G6 single contact bayonet LED. C-6, C-2R filament design compatible, single filament Uses only 1 Watt at 6 volts. Uses very low power. The profile is very small to match the profile of the #63 bulb. The light output is up to 90 Lumens the #63 bulb has a rated output of 3 candle power CP, the LED is up to 6 candle power so about twice as bright as stock light bulb. This bulb is available in White 6000K, Warm White 3000K, Red 625 nm, Green 526 nm, Blue 464 nm & Yellow 594 nm" |
09-29-2020, 08:45 AM | #7 | |
And yes, looks like the right one. |
