Old 09-07-2019, 06:35 PM   #1
Ideucev8
Default 32 pickup seat back mounting
How is the seat back mounted? I have done a search here & on the web, some pics show 2 lower mounting brackets & some show 3. Do these brackets just push through the upholstery?
Is there meant to be mounting brackets at the top? It looks like it may of had something around each side across the top of my original seat back spring, and a hole in line in the body wood for a wood screw. If so would anyone have a photo of this please.
Thanks, Phil
Ideucev8 is offline   Reply With Quote
Old 09-07-2019, 11:07 PM   #2
Newc
Newc's Avatar
Default Re: 32 pickup seat back mounting
H; the seat springs used at least two hangers screwed to the nr top of the verticle wood strips in the cab back. Newc
Old 09-07-2019, 11:58 PM   #3
DavidG
DavidG's Avatar
As shown below. Two below and three on top.
Old 09-08-2019, 02:31 AM   #4
Ideucev8
Thanks for the replies. Do the top ones stick up through a slot in the upholstery or sit on top of it & go around the back?
Thanks Phil.
Old 09-08-2019, 07:16 AM   #5
DavidG
DavidG's Avatar
They're behind the upholstery attached to the back of the cushion spring assembly.
Old 09-08-2019, 02:42 PM   #6
Ideucev8
Thanks David.
