Old 04-30-2021, 03:52 AM   #1
HomeBuilt
Default Can anyone id this generator?
It was fitted to a Model A and the bracket has been modified to suit. It looks like V8 but the bracket, front end plate and pulley are different. The pulley threads on to the armature with no key or nut although the armature does have a keyway so would take a standard pulley. The original bracket looks like it was used to offset the generator and was adjustable with a slot. There is no allowance for a fan. Part number appears to be Ford V-1C and I can't see any part numbers elsewhere. I am assuming 6V 35A as that's what regulator it had.
Web search has proved fruitless.
Thanks in advance.
HomeBuilt is offline   Reply With Quote
Old 04-30-2021, 06:18 AM   #2
mfirth
Default Re: Can anyone id this generator?
I'm NO EXPERT, but, looks like tractor or industrial to me ???
mfirth is offline   Reply With Quote
Old 04-30-2021, 06:24 AM   #3
ponymare
1947 back G series 6 cyl used a set up like that.
ponymare is offline   Reply With Quote
Old 04-30-2021, 08:46 AM   #4
HomeBuilt
Thanks ponymare. Easier to find when you know what to look for.
