Old 04-12-2021, 08:02 PM   #1
BoxCar Tom
BoxCar Tom's Avatar
Default Soooo close
Soooo Close. Two car garage, have to walk outside to turn around
BoxCar Tom is offline   Reply With Quote
Old 04-12-2021, 08:12 PM   #2
Zeke3
Zeke3's Avatar
Default Re: Soooo close
I think it is more like a 1.5 car garage the way those two bodies are squeezed together.
Zeke3 is offline   Reply With Quote
Old 04-12-2021, 08:14 PM   #3
Lawson Cox
Lawson Cox's Avatar
How do you get in and out of the car? Align it up as close as you can and push it in and pull it out with a rope????
Old 04-12-2021, 09:21 PM   #4
Jay in Mass
You really have your hands full with that garage space problem.
Jay in Mass is offline   Reply With Quote
Old 04-13-2021, 06:53 AM   #5
mfirth
Too close for comfort.......
mfirth is offline   Reply With Quote
Old 04-13-2021, 09:21 AM   #6
1931 flamingo
1931 flamingo's Avatar
Just got a 24x24 for that reason.
Paul in CT
Old 04-13-2021, 09:22 AM   #7
5851a
Same here, when I put my pick up in the pole building I fold the mirror in case the tire would go flat and it would dent the hood on my old truck.
5851a is offline   Reply With Quote
Old 04-13-2021, 12:58 PM   #8
1ton
It's almost like if either of those cars had another coat of paint they would not fit.
1ton is offline   Reply With Quote
Old 04-13-2021, 01:49 PM   #9
Mart
Mart's Avatar
"Soooo Close."
Toooo Close!
Old 04-13-2021, 03:56 PM   #10
3quarter32
3quarter32's Avatar
With the price of lumber now, to build a larger garage, it may be less expensive to get smaller autos.
3quarter32 is offline   Reply With Quote
Old 04-13-2021, 04:16 PM   #11
mercman from oz
mercman from oz's Avatar
Wow, That is close. That Mirror should go before it does damage to the Coupe Body.
Old 04-14-2021, 04:24 PM   #12
BoxCar Tom
BoxCar Tom's Avatar
Same 2 car garage with 3 32s about 15 years ago. Yup that's the a 32 frame stuck to the wall. And if you have extra eagle eyes you might recognise the green lamp rescued from the debris of the defunct Edgewater NJ Ford Motor Company Assembly Plant.
Old 04-14-2021, 05:11 PM   #13
mercman from oz
Heavy work getting that 32 Frame mounted on the wall?
Old 04-14-2021, 06:19 PM   #14
hop up
hop up's Avatar
That looks like a good problem to have too many 32s
Wanted flathead speed equipment Thanks
hop up is offline   Reply With Quote
Old 04-14-2021, 06:37 PM   #15
BoxCar Tom
BoxCar Tom's Avatar
Nope, actually did it by myself, leaned it against the wall, put a 5 ga bucket under one end, put a bucket under the other end, stepped it up by adding a bucket at each end. Had a makeshift removable bracket to hold it against the wall on the way up. Took a good hour. I needed the floor space.
