Old 03-01-2021, 03:34 PM   #1
rockfla
rockfla's Avatar
Default Oil hole on the back of the block
Is the oil hole on the back of a V8 block 1/8 NPT Thread????
Old 03-01-2021, 03:54 PM   #2
cas3
Default Re: Oil hole on the back of the block
the two ports for the sending unit, and the filter line are 1/4" npt, if thats what you are lookin for
Old 03-01-2021, 03:56 PM   #3
Ol' Ron
Ol' Ron's Avatar
I think iy 3/8 NPT? but my memory is not very good these days.
Gramps
Old 03-01-2021, 04:03 PM   #4
51 MERC-CT
51 MERC-CT's Avatar
"The" oil gallery plug should be 1/4 pipe.
Old 03-01-2021, 04:22 PM   #5
rockfla
rockfla's Avatar
Yyyeessss, exactly what I was looking for!!! THANK YOU....now I can get every thing I need before I start so I don't have to stop and run to the parts store in the middle of the job!!!!!! Only thing is "mine" only has one, not two.....the oil sender AND the oil filter line are coming out of ONE brass tee block on the back of the block!!! SO now I have to figure how to get my mechanical gauge into the loop!!!
Old 03-01-2021, 07:50 PM   #6
V8COOPMAN
V8COOPMAN's Avatar
Yyyeessss, exactly what I was looking for!!! THANK YOUThe oil sender AND the oil filter line are coming out of ONE brass tee block on the back of the block!!! SO now I have to figure how to get my mechanical gauge into the loop!!!
Use this 4-way with a "close", or short nipple into the block. DD
eBay Item #361468769649 as an example....$7 bucks!
Click Links Below __
T5 W/TORQUE TUBE
Old 03-02-2021, 07:45 AM   #7
rockfla
rockfla's Avatar
Exactly what I was looking for...Thanks V8Coupeman.....AND there IS two holes......I just couldn't see under the sender and with all the "grime" on the back of the engine. Thanks again ALL for your help!!!
Old 03-02-2021, 08:20 AM   #8
marko39
You can tee into line at oil filter inlet for mech. Gauge, much more accessible.
marko39 is offline   Reply With Quote
Old 03-02-2021, 08:33 AM   #9
rockfla
rockfla's Avatar
Yes, saw that this morning!!! Thanks. I actually got a 3 way one, a male end for the block and two females, one for the mechanical gauge and one for the oil filter line!!!
