04-22-2021, 04:23 PM | #21 |
Re: dump tubes
Are you using the term Scavenger Pipes the same as Lake Pipes?
04-22-2021, 08:24 PM | #22 |
Re: dump tubes
04-22-2021, 08:42 PM | #23 |
Re: dump tubes
04-23-2021, 06:50 AM | #24 |
Re: dump tubes
We had scavenger pipes in Ohio and a had them on a 55 Customline I Block 6 with split manifold. Split 2 & 4, sounded like a V8 at idle. Had to be at work, no time for mufflers, so straight pipes with scavengers. Yes, got nailed on the way home from work. Mufflers the next day & when i took it for inspection, the Trooper said; "man that thing sounds cool"
Yup, the good ole days. |
