Old 01-30-2021, 04:08 PM   #1
KenBolton
Default Dispatch Pocket Wood
Do the ‘30-31 pickup dispatch pockets require wood blocks or was this required only for ‘28-29’s?
KenBolton is offline   Reply With Quote
Old 01-30-2021, 04:52 PM   #2
rfitzpatrick
Default Re: Dispatch Pocket Wood
No wood blocks needed. The pocket comes with medal strips that go behind the kick-panel that you will attach the pocket on for the other side. Everything is in the kit.
This meant for the 30/31's
rfitzpatrick is offline   Reply With Quote
Old 01-31-2021, 11:37 AM   #3
KenBolton
Thanks! That is what I remembered too but Affordable has blocks on-sale for all years.
Old 01-31-2021, 12:11 PM   #4
Bob C
Actually they show 1928-1930 which would be for the 82-A body
used till mid 1930. https://www.mikes-afordable.com/product/AWD1282-5.html
Old 01-31-2021, 12:13 PM   #5
Bob C
Double post
Old 01-31-2021, 12:49 PM   #6
McMimmcs
McMimmcs's Avatar
my friend added his later and attached with Velcro strips. Functional and looks good.
Old 01-31-2021, 01:50 PM   #7
CHuDWah
CHuDWah's Avatar
Note the late-30 - 31 dispatch pocket is mounted at an angle on the passenger kick panel:
File Type: jpg Cab 82-B Dispatch Pocket - Neil Wilson.jpg (61.5 KB, 11 views)
CHuDWah is offline   Reply With Quote
Old 01-31-2021, 01:59 PM   #8
CHuDWah
CHuDWah's Avatar
Seems it would be just as easy to mount correctly with 1/2-dozen rivets, but whatever.
Old 01-31-2021, 05:52 PM   #9
McMimmcs
McMimmcs's Avatar
If not high point car it’s doesn’t matter as long as it looks good. I’d rather not drill holes when not necessary.
