Old 04-19-2018, 05:52 AM   #1
mfirth
Default valves to tight ?
How does an 8ba sound & act if valves are adjusted too tight? Lumpy idle & low compression? This is a fresh rebuild by a reputable builder. THANKS for any imput!!! mike
mfirth is offline   Reply With Quote
Old 04-19-2018, 05:55 AM   #2
mfirth
Default Re: valves to tight ?
Forgot to mention this is a stock 8cm cam.
Old 04-19-2018, 06:33 AM   #3
ponymare
If exhaust valves are too tight you can hear it at the tail pipe, if intake valves you'd hear it popping back through the carb.
ponymare is offline   Reply With Quote
Old 04-19-2018, 06:33 AM   #4
Frank Miller
Frank Miller's Avatar
Too tight will result in a rough idle as will a few other things. Connecting a vacuum gauge or doing a compression check can determine if you have a problem with the valves or not.
“The technique of infamy is to start two lies at once and get people arguing heatedly over which is true.” ~ Ezra Pound
Frank Miller is offline   Reply With Quote
Old 04-19-2018, 09:02 AM   #5
mfirth
Thanks guys....Frank, comp is only 50-70 new build 400 offy heads.
Old 04-19-2018, 09:05 AM   #6
JSeery
JSeery's Avatar
The very first thing I would do is contact the builder! First you need his input and second if you mess with it without first contacting the builder you will most likely void any warranty.
Old 04-19-2018, 09:06 AM   #7
mfirth
Thanks J already going that direction.
Old 04-19-2018, 09:58 AM   #8
mfirth
I just checked vac...very low & needle jumps around a lot! Sounds like a valve issue since dizzy & carb are known good units....yes?
Old 04-19-2018, 10:47 AM   #9
flatjack9
flatjack9's Avatar
Compression should in the 120 range at least.
flatjack9 is online now   Reply With Quote
Old 04-19-2018, 11:53 AM   #10
JWL
The first thing you will notice is the engine will have very low power until high RPM are reached.
JWL is offline   Reply With Quote
Old 04-19-2018, 06:27 PM   #11
mfirth
JWL yup as rpm increases it sounds better & smoother.....thanks to each one of you for your thoughts! The builder will get the car & says they will make it right....God is good & i feel the builder is too.
Old 04-19-2018, 06:30 PM   #12
mfirth
Special thanks to all for help & support ... the Barn is GR8 !!!! mike
