07-12-2011, 03:25 PM | #1 |
Tillotson carb problem
I rebuilt Our tillotson over a year ago and she has been working great ...
I Had someone else drive her in a parade on the weekend and the engine barely stayed running and was kicking out black smoke ... very rich ... Found out that the person opened the choke control rod CCW a full turn .Not sure why he did that .. I normally run it at a 1/4 turn ... So I turned it back to normal ( 1/4 turn )and she still runs rich ... I had to turn it all the way in CW to make her run better ... Any idea's as to what is or went wrong ? I need to do a couple of small shows over the next week and she should be OK for that ,but should I plan on rebuilding the carb later next week? Has anyone tried the new Tillotson that Mac is selling ?--- I would like to have a spare on the shelf Last edited by Pepsi Mechanic; 07-12-2011 at 03:30 PM. |
07-12-2011, 03:51 PM | #2 |
Re: Tillotson carb problem
possibly it was seated too hard before it was turned out a full turn and expanded the orifice. Or, there could have been a speck of dirt in there that washed out when it was fully opened, thereafter allowing greater fuel flow.
07-12-2011, 04:00 PM | #3 |
does that carb have a removable seat like the early Zenith which may have unscrewed with the needle?
07-12-2011, 04:06 PM | #4 |
07-12-2011, 04:12 PM | #5 |
I highly doubt it
In fact I'd bet it would run really rich. |
07-12-2011, 04:33 PM | #6 |
07-12-2011, 04:43 PM | #7 |
Sure, kind of like it would if the seat was stuck to the needle and simply getting pushed against its own threads when the needle is threaded in. When you unscrew the needle its pulling the entire seat out leaving a huge hole instantly.
I would pull it apart and see if that is the case or not. |
07-12-2011, 04:49 PM | #8 | |
07-12-2011, 10:31 PM | #9 |
There is no screw in seat on a Tilly. It is part of the casting.
http://members.fortunecity.com/pjsauber/TillyCarb.htm |
07-13-2011, 11:29 AM | #10 |
if the screw was really torqued down by the driver, it might have deformed the needle, seat or both. I'd screw the needle all the way out and see if it has a 'stairstep' that might have been pressed into it? If the 2 sides were deformed, it might make it a bit more 'sensitive' to flowing fuel.. Also if it was opened "way" up and the throttle was pushed down creating full vacuum, the passageway in the GAV deep in the carb could have been flushed, allowing a larger volume of fuel to be passed through the now flushed/cleaned passageway.
My 2 cents.. Hope it helps |
07-13-2011, 04:35 PM | #11 |
Everyone's advise is always welcome ... I have a new carb coming in from Mac's for Thursday ... I will swap out the carb and make sure the girl is running ... need it for a major event on Monday ... then I will at my leisure take the old carb apart and investigate the issue ... I have a rebuild kit on the shelf so this way I will always have a spare for a quick change if need be .. She gets driven by a few different people over the year and no matter how many times you explain everything it just does not always sink in ... Thats OK .. thats why I am around ... I love fixing her just as much as driving her
07-13-2011, 05:07 PM | #12 |
Just be warned, I installed a new carb on our Model A over a year ago so my boss could drive it 2 hours to his house and he ended up broke down with a sunk float. I also fought with the GAV not working right until a few days ago.
All I'm saying is be aware just because its new doesn't mean its reliable or works right. |
07-13-2011, 06:20 PM | #13 | |
