Old 05-15-2022, 08:03 AM   #1
Veeder
Default 41 ignition switch rebuild
I’ve spent way to many hours on this to date only to end up mounting a set of switches under the dash to bypass the stock switch. I want to go back to the stock switch but nut until I have it perfect. Are there any suppliers of all the components that go in the metal enclosure or ideally the whole switch assembly?
Thks in advance
Also any links for rebuilding this thing would be helpful.
Veeder is offline   Reply With Quote
Old 05-15-2022, 09:18 AM   #2
RKS.PA
RKS.PA's Avatar
Default Re: 41 ignition switch rebuild
I just "rebuilt" mine. Not sure if your '41 is like my '47, but I replaced the switch plate inside the metal enclosure...part # 09A-3704. The rest of the "innards" were in good shape. C&G Ford Parts had what I needed, but there were a bunch of switch related parts on Ebay.
You will have to pry the cover off the enclosure...it's kind of riveted on, but the two mounting screws will hold the cover in place when you put it back together.
Good luck, it will be good to get rid of the "band aids"!
RKS.PA is offline   Reply With Quote
Old 05-15-2022, 09:32 AM   #3
Veeder
Thks I’ve had this switch all apart a few times I also made a tapered screw that holds it all in place because the case openings are about 7/32 and the screw is only1/8 in dis so that left a fair amount of play.
I’ll check out c|g ford later
Thks
Old 05-15-2022, 09:36 AM   #4
slowforty
slowforty's Avatar
I used a piece of thread to hold the movable part in place . It gets interesting trying to hold the switch together while installing the switch. while upside down on the seat.
slowforty is offline   Reply With Quote
Old 05-15-2022, 12:01 PM   #5
RKS.PA
RKS.PA's Avatar
Yes, it does....particularly with my 79 year old body!!! (Getting under there wasn't as challenging as betting back out again!) I thought about using some Gorilla super glue on the two ears once I assembled the switch on the bench, but made do without that.
Old 05-15-2022, 10:04 PM   #6
fordor41
fordor41's Avatar
When I rebuit mine, I taped the two halfs together with small pieces of painters tape on the edges. when almost tight I pulled the tape off and tightened.
fordor41 is offline   Reply With Quote
