Old 01-28-2011, 02:52 PM   #1
wallymelton
Default 32 vs 34 cab
what differences are there between the 32 ford b cab and the ford 33-34 1/2 ton truck cab? size, moldings, mounts, etc.? thanks
wallymelton is offline   Reply With Quote
Old 01-28-2011, 03:07 PM   #2
deuce lover
deuce lover's Avatar
Default Re: 32 vs 34 cab
For one the Firewall in the 32 is different and removable.Dash is different.32 has opening for the guage tunnel.
Old 01-28-2011, 05:26 PM   #3
Newc
Newc's Avatar
Hi; 32 cabs have some odd points: early 32's have reveal indents where the door edge closes, The tops are welded on the A pillars and the seam leaded, The tops DO NOT have a reinforcing ridge near the visor, some visors DO NOT have a center reinforcing brace, Cowl vents are early/late angles, ALL 32's have under seat gas tanks/ Split seat bottoms. Door hinges DO NOT have reveals around the hinge openings. These are just what I can remember. Join Early ford V8er's Newc
Old 01-28-2011, 05:51 PM   #4
Flathead Fever
Flathead Fever's Avatar
'34 Cabs have an extra wide belt line across the back of the cab
Old 01-28-2011, 10:51 PM   #5
jerseyboy
jerseyboy's Avatar
Here's some good info on how to tell the two apart:
http://www.fordgarage.com/pages/cabidentification.htm
Ah Vince, what would we do without him
keep V-8ing and 4-banging!
She just don't have the appetite
For gas somehow,
And Dad, I got four carburetors
Hooked up on it now.
I tried to hook another
To see if I'd do a little good,
But ain't no place to put it
'Less I perforate the hood.
Wanted, lower side sections of 32 radiator cowl.
jerseyboy is offline   Reply With Quote
Old 01-29-2011, 12:59 PM   #6
wallymelton
Is the cab width the same?
Old 01-29-2011, 01:20 PM   #7
FlatheadTed
FlatheadTed's Avatar
Yes it the same width .
http://www.flatheadted.com
Flathead Ted brake Floaters ,
Old 01-30-2011, 07:49 AM   #8
HOTRODPRIMER
HOTRODPRIMER's Avatar
Late 32 cabs do have the reinforcing bead near the visor.HRP
‘When one door closes, another opens. But we often look so regretfully upon the closed door that we don’t see the one which has opened for us.’ Alexander Graham Bell
HOTRODPRIMER is offline   Reply With Quote
