Old 10-04-2022, 01:23 AM   #1
1946
1946's Avatar
Default Five bearing camshaft
A question re camshafts: I have a five bearing camshaft and the motor only has the normal three bearing camshaft housing in the block, Can I use this in my rebuild, or is it better to seek out the standard three bearing shaft. Is there a difference in the grinds on the shafts, and am I correct in thinking the five bearing shaft is a very early one. The car is only used for general club outings.
Tassie Devil
1946 is offline   Reply With Quote
Old 10-04-2022, 04:25 AM   #2
Synchro909
Synchro909's Avatar
Default Re: Five bearing camshaft
There is no problem using a 5 bearing cam in a 3 bearing block.
Old 10-04-2022, 11:40 AM   #3
Jim Brierley
There were 3 different 5-brg. cams made, all 3 with the same lobe profile. The first had all 5 brgs. ground to the same size, and were designed for the 5 brg. block. The second batch had all brgs. ground but #2 & 4 were of a smaller diameter, this allowed that cam to be installed quicker during production. The third batch #2 & 4 were merely rough-turned on a lathe. The first batch cams are desirable as they can be used in the new Burtz engine. Most will likely need to be re-ground because of wear, easy to do.
Old 10-04-2022, 12:42 PM   #4
ursus
The 5-bearing cams that were turned down for use in 3-bearing blocks have shorter bearings so there is less meat on the stick at the journals. I have to wonder how well these hold up to wear as compared to the 3-bearing cams. Ford apparently thought it was OK to recycle them into new blocks but was Henry just being cheap?
ursus is online now   Reply With Quote
Old 10-04-2022, 05:16 PM   #5
1946
1946's Avatar
Thanks all, according to Jim's note the cam I have is in the last batch, as it has rough turned #'S 2 and 4 bearing and these are both smaller than the #'s 1,3,and5 on the shaft. I have a 3 bearing shaft and will use that. Thanks again for the comments.
Tassie Devil
Old 10-04-2022, 05:29 PM   #6
Gene F
Gene F's Avatar
If you ever take it to an A shop, they will try to give you a 3 journal. Generaly speaking I guess old timers want the 5 journal can.
