Old 01-12-2018, 12:11 PM   #1
1931flathead
Default ford 4 spd overdrive to 59ab
what kind of a bell housing do I need to do this pics of the transmission
1931flathead is offline   Reply With Quote
Old 01-12-2018, 12:18 PM   #2
cas3
Default Re: ford 4 spd overdrive to 59ab
never done it, but i'm sure folks are using a bell off the front of a truck 4spd. there was even a guy making the adaptor for the torque tube i believe. you'll have to ask mr google, he knows every thing
Old 01-12-2018, 12:22 PM   #3
1931flathead
Open drive line
Old 01-12-2018, 01:59 PM   #4
corvette8n
corvette8n's Avatar
I think Ol Ron has done that, search his posts.
Old 01-12-2018, 03:35 PM   #5
john in illinois
john in illinois's Avatar
https://fordbarn.com/forum/showthrea...highlight=f150
John
john in illinois is offline   Reply With Quote
Old 01-12-2018, 08:26 PM   #6
51504bat
51504bat's Avatar
Model Engineering makes an adapter fora Ford 4 speed top loader trans which I believe is the same config as the 3 + 1 O/D trans you have. I have one for the 4 speed and its high quality.
Old 01-12-2018, 08:49 PM   #7
1931flathead
that what I was looking for thanks
Old 01-12-2018, 10:09 PM   #8
Jay in Mass
I used the bell off the front of a flathead Ford 4 speed and made a simple flat aluminum plate to that same RTS transmission. It works just fine with the overdrive and the synchromesh first gear. Did this to at least a half dozen flathead engines.
Don't know how to put the pictures on this site, but can send them to an email address.
Jay in Mass is offline   Reply With Quote
Old 01-12-2018, 10:16 PM   #9
JSeery
JSeery's Avatar
I can post them for you if you like. [email protected]
Old 01-12-2018, 10:20 PM   #10
electricman
Could you send pics to [email protected]. I am interested in that application. Thanks
electricman is offline   Reply With Quote
Old 01-12-2018, 10:22 PM   #11
1931flathead
I can post them to I sent you a pm thanks
Old 01-12-2018, 10:23 PM   #12
JSeery
JSeery's Avatar
All kind of help!
Old 01-12-2018, 10:34 PM   #13
1931flathead
here is a pics from modelengineeringco
thank jay for the pics but I could not post them
Old 01-12-2018, 10:34 PM   #14
Jay in Mass
1931
Please post the pictures that I just sent you. I'm not very good with computer stuff.
Jay
Old 01-12-2018, 10:40 PM   #15
1931flathead
I sent them to jseery I could not do anything with them for some reason
Old 01-12-2018, 10:58 PM   #16
JSeery
JSeery's Avatar
Ok, headed home.
Old 01-13-2018, 03:18 AM   #17
tjw
tjw's Avatar
Ford 3+1 overdrive [ 4 speed ] conversion to retain closed drive.
I will have this conversion kit on display at the Pate swap in April together with all the other products I manufacture.
tjw is offline   Reply With Quote
Old 01-13-2018, 09:27 AM   #18
Ol' Ron
Ol' Ron's Avatar
Yes, I did this to an 8BA in my 47 with a spicer 44A rear,. really works like a dream. I used a stock stamped steel bell housing and welded on some tabes after boting out the regester to the same size as the tran,. another way to do this id with a Hogs head adapter for the 59. I realize most prople dont have the machinery to do this, but if you know sombody with a mill, it's pretty easy.
Old 01-13-2018, 09:35 AM   #19
JSeery
JSeery's Avatar
Here are the photos Jay was wanting posted. They are of two different transmission bolt patterns, but the concept is the same for both. This is the approach I use for T5 adapters using a "Hogshead" for the bellhousing part.
www.jalopyjournal.net www.jalopyjournal.net" This is what I did.www.jalopyjournal.net I use the exact same transmission that you have in your picture.www.jalopyjournal.net It's simple.www.jalopyjournal.net www.jalopyjournal.netThere is nothing to it."
Jay
One of the first steps is to determine the input shaft length which determines the thickness of the adapter plate.
Note: Sorry it took so long!!! My wife had surgery yesterday and spent most of my time at the hospital. Running a little behind.
Old 01-13-2018, 09:50 AM   #20
1931flathead
hope your wife is doing good
