02-12-2020, 07:30 PM | #1 |
Teflon EZ Steer Kit what do you think?
I have everything apart, so I was thinking of installing the ez steer kit, but I am unsure.
What are your thoughts on this product. Have you used it? Did it help? Did it not make a difference? Worth the money? https://www.snydersantiqueauto.com/P...earchByKeyword |
02-12-2020, 07:38 PM | #2 |
Re: Teflon EZ Steer Kit what do you think?
02-12-2020, 08:08 PM | #3 |
I didn't see much difference. But the shortened pitman made a big difference.
Bill Worden 1929 Roadster 1929 Briggs Town Sedan 1930 Closed Cab pickup Smith Motor Compressor 1951 Ford F1 High Desert Model A's |
02-12-2020, 08:27 PM | #4 |
I use them.
02-12-2020, 08:29 PM | #5 |
I installed the teflon kit. Didn't make a real big difference but helped some. Ensure your balls are round...
Like Bill said, the shorter pitman arm made a big difference. |
02-12-2020, 08:43 PM | #6 |
02-12-2020, 09:45 PM | #7 |
Is it just me, or is this item tricky to find in Snyder's on line cattle dog?
Down the left, not under steering, not under front axle. A search of steering, Model A ... not there. A search of "steer" brings it up. Haven't seen the steel ones listed yet, or the bronze impregnated ones. Are the bronze ones better? |
02-13-2020, 12:03 AM | #8 |
I've never seen bronze ones, but they may work nicely.
02-13-2020, 12:54 AM | #9 |
02-13-2020, 07:58 AM | #10 |
https://www.mikes-afordable.com/product/A3305M.html
Here they are about $20 cheaper. Says they are longer wearing compared to the other teflon seats. I am planning to use the regular teflon when I redo my front end. |
02-13-2020, 09:17 AM | #11 |
I used the bronze ones. Figured I only wanted to rebuild the darn thing once. Less resistance than steel, but no different from the regular teflon in terms of performance.
02-13-2020, 09:58 AM | #12 |
I question the longevity of the Teflon ball socket parts. How many miles before replacement?
Perhaps a grease with a Teflon additive is just as good and much less expensive?
Bob Bidonde |
02-13-2020, 11:50 AM | #13 |
02-13-2020, 10:04 AM | #14 |
I’ve been using the Teflon-bronze kit from Mike’s in Georgia. Their current price is $73.25 and I have installed them on three of my cars.
I have them on my slant window sedan and I kept the pitman arm stock. I’m happy with the steering. |
02-13-2020, 10:05 AM | #15 |
I would think if the inserts themselves were available it would be more affordable and I probably would give it a go.
02-13-2020, 10:13 AM | #16 | |
https://www.snydersantiqueauto.com/P...S-ONLY-8-PIECE |
02-13-2020, 10:32 AM | #17 |
You will need the correct plugs to use those inserts though. Can't use the stock ones.
02-13-2020, 10:42 AM | #18 |
Ah good point
02-14-2020, 12:07 PM | #19 |
And too repeat, no amount of fancy material will compensated for steering arm balls that are too worn.
I know the voices aren't real but damn they have some good ideas! |
02-14-2020, 06:31 PM | #20 |
I have then on my two cars plus I had the ball ends replaced . Also have the pitman arm shorten .have had no problems with them . Getting ready to build a husker style delivery and plan to do the same .
