Old 05-20-2024, 09:58 AM   #1
rockfla
rockfla's Avatar
Default One Head stud too short each bank follow-up
So I posted a little over a week ago about one "short" head stud being too short to fully engage the head hex nut. Michael sent me a packet of about 6 more studs......NOTE on the ones he sent the amount of smooth shank compared to the "short" one I have....even though its only about 1/8th to 3/16 of an inch over all longer, the amount of smooth shank "MAY" be the difference maker??? I will report back soon!!!
Also, I looked around and decided to try these Mil Spec flat washers. I am quite happy with them as you can see a much tighter fit under the nut and less obtrusive looking.
Old 05-20-2024, 10:21 AM   #2
Bored&Stroked
Bored&Stroked's Avatar
Default Re: One Head stud too short each bank follow-up
Yeah, I use the smaller diameter washers - though they come with my ARP studs. They don't protrude as much and don't have issues with the spot-facing on the aluminum heads. (Being too wide). Also, I like the Grade 8 or better mil-spec washers - as they don't gall like the Grade 5 stuff does. This gives a much more accurate torque reading.
Old 05-20-2024, 10:49 AM   #3
GB SISSON
GB SISSON's Avatar
Those 'mill spec' washers in 1/2" would be just right on main bearing caps.
Old 05-20-2024, 10:57 AM   #4
Bored&Stroked
GB: You should checkout the ARP stud kits for the mains - not too expensive and have really nice hardware. I think Red's Headers has them for around $50 or so?
Old 05-20-2024, 11:06 AM   #5
petehoovie
petehoovie's Avatar
The only thing nice about being imperfect is the joy it brings to others....
"Silver rings, your butt! Them's washers!"
"We shot our way out of that town for a dollar's worth of steel holes!" - from 'The Wild Bunch' - 1969
https://www.youtube.com/watch?v=7NReUd2_0u0
Old 05-20-2024, 11:41 AM   #6
Seth Swoboda
Seth Swoboda's Avatar
I believe there is one longer stud for the firewall to ground strap.
Seth Swoboda is offline   Reply With Quote
Old 05-20-2024, 11:42 AM   #7
rockfla
rockfla's Avatar
NOT on 1935. A little later though
Old 05-20-2024, 11:48 AM   #8
Seth Swoboda
Good to know. I learned something. I would guess that started in 1937??
Old 05-21-2024, 06:59 PM   #9
Tim Ayers
Robert,
Did the new studs fix the problem?
Old 05-22-2024, 06:48 AM   #10
Bored&Stroked
I was laughing this AM at the title of this thread ---> kind of a way of mentioning a friend who isn't the "brightest bulb in the pack":
"I know Ole Tom . . he is one head stud too short. . . ."
That might be my new saying for those who are mentally challenged . . . thanks Rock!
Old 05-22-2024, 09:31 AM   #11
rockfla
rockfla's Avatar
Originally Posted by Tim Ayers View Post
Robert,
I've drug up sorry the last couple of days, I will let you this evening OR first thing in the AM. Sorry!!! BUT I will let you know ASAP
Old 05-22-2024, 11:46 AM   #12
Tim Ayers
No rush on my end. Just curious.
B&S,
Without a doubt I've been accused of being one stud short of 24.
Old 05-22-2024, 11:56 AM   #13
rockfla
rockfla's Avatar
Tim
I am pretty confident that it will work, IF you look at my picture and see where the stud bottoms out to the block, the smooth shank is about 3/8" longer than what I had (ie move the fine thread end out 3/8") SO that "should" (theoretically) give me the other 1/4"+ extra needed to full engage the threads of the hex nut.....BUT will confirm shortly for you.
Thanks to Michael as per usual, Third Gen Stepped up SO once again KUDO's to Michael
Old 05-22-2024, 01:13 PM   #14
Bored&Stroked
B&S,
Tim: Only one stud short of 24 . . . you bragger you! LOL
Old 05-22-2024, 01:54 PM   #15
Tim Ayers
Hahahaha
Old 05-22-2024, 05:14 PM   #16
rockfla
rockfla's Avatar
Tim
The quick answer is YES, it worked perfectly. I forgot to take my phone with me to the shop, AND forgot to take the second stud with me as well SO I will post pictures first thing in the AM!!!
Old 05-22-2024, 06:06 PM   #17
Tim Ayers
Tim
Excellent news!
Old 05-23-2024, 06:44 AM   #18
rockfla
rockfla's Avatar
Here is the final pictures of the outcome. I had to use two jam nuts to install the new stud with the head on, my stud remover/installer would have grabbed onto the threads SO Plan B. Resealed the threads and anti-seized the shank and in they went. All is good
Old 05-23-2024, 07:47 AM   #19
Bored&Stroked
Looking great . . . fire that baby up! LOL
Old 05-23-2024, 08:02 AM   #20
rockfla
rockfla's Avatar
Thank's B&S, I appreciate the kind words and inspiration!! Its going to Norway SO I do have to figure a way to "Fire it Up" before I ship it.....WOULD make me feel a whole lot better knowing its tip top before it leaves me!!!!
