Old 04-11-2021, 07:49 PM   #1
KNicholas2
Default Horn problems
The horn on my "31 coupe does not work.
I checked - it is receiving 6 volts of power when the horn button is pushed. I can hear a subtle "click" but the horn motor will not rotate.
If I manually rotate the shaft is seems to move easily.
Suggestions?
KNicholas2 is offline   Reply With Quote
Old 04-11-2021, 08:53 PM   #2
700rpm
700rpm's Avatar
Default Re: Horn problems
Back off the adjusting screw a few notches. If it then turns, close it down till you get the sound you want. See that the commutatiors are clean and shiny, and that the brushes are making good contact. Also make sure the felt on the ends of the armature are lightly oiled.
Ray Horton, Portland, OR
Old 04-11-2021, 09:21 PM   #3
Bob C
The horn always has 6 volt to it, the ground is through the horn button on the steering wheel.
Old 04-12-2021, 02:09 AM   #4
28Danby
I've had a similar problem. Turned out the diaphram was dickered. Rebuilt the horn, was cheap and easy to do and sounds great.
28Danby is offline   Reply With Quote
Old 04-13-2021, 11:54 AM   #5
Jacksonlll
Jacksonlll's Avatar
Send a message via ICQ to Jacksonlll
Back off the adjustment screw until the motor spins freely. No sound. Assuming it will run when the button is pushed, Let the motor spin for about 15 or 20 seconds. This may loosen things up.
Jacksonlll is offline   Reply With Quote
Old 04-13-2021, 12:18 PM   #6
Big hammer
And a few drops of a light weight oil on the felts and bushings, might be another good use for MMO !
get a bigger hammer tap done
Old 04-13-2021, 04:33 PM   #7
Badpuppy
Horn button contact may be crusty. Connect a solid ground to the horn button side of the motor (the side that doesn't burn your fingers). If it spins, you need to clean up the button contact.
Badpuppy is offline   Reply With Quote
Old 04-13-2021, 04:35 PM   #8
Badpuppy
(deleted)
Old 04-14-2021, 03:39 PM   #9
Ivan in southeast va.
Ivan in southeast va.'s Avatar
I would check the commutator and see if it is dirty. I take a small piece of a scotch-brite pad with a little wd-40 on it and spin the motor by hand while cleaning the commutator.
Ivan in southeast va. is offline   Reply With Quote
Old 04-14-2021, 05:35 PM   #10
1crosscut
1crosscut's Avatar
Pull the cover off and run jumper wires directly from the battery. If it sounds good then you're troubles are elsewhere.
Dave / Lincoln Nebraska
1crosscut is offline   Reply With Quote
Thread Tools
Display Modes
