Old 04-10-2020, 01:24 PM   #1
Ken/Alabama
Ken/Alabama's Avatar
Default Tools for setting valve lash
My friend and long time machinist gave these to me today. His Dad ran a machine shop in Montgomery Ala back in the 40s and it stayed open until the late 1990s. Back in the day they rebuilt lots of flatheads and had a row of about 10 KRW engine stands bolted to the floor. He said these were used to put pressure on the cam while the valve lash was set . The skinny part is under spring pressure and is inserted down through the guide hole and rest against the lifter. Then you push down on the big end sticking up and insert a horseshoe keeper. Thought they were kinda neat, never seen or heard of them before . Don’t see any name on them .
File Type: jpg 2C14EA2F-180F-4592-BE10-1EFEC67C925F.jpg (56.5 KB, 140 views)
Ken/Alabama is offline   Reply With Quote
Old 04-10-2020, 04:06 PM   #2
Don
Don's Avatar
Default Re: Tools for setting valve lash
Can’t figure it out yet!!! I’ll keep thinking about !!!
DON P
Don is offline   Reply With Quote
Old 04-11-2020, 03:25 PM   #3
Russ/40
Russ/40's Avatar
I had the same reaction. I believe the brain trust lost some info. I believe they are used to grind the valve seats. They make it possible to maintain good centricity without the use of a guide. The small end is spring loaded for raising and lowering the grinding stone off the seat when you want to start and stop seat cutting.
Not sure what the grooves top and bottom do to enhance the result, unless they are to use keepers to fix the position of the mandrel.
Russ/40 is offline   Reply With Quote
Old 04-11-2020, 03:31 PM   #4
Don
Don's Avatar
Makes sense now. With spring loaded guide ,believed it used for hand lapping
DON P
Old 04-11-2020, 07:30 PM   #5
Ken/Alabama
No, they are made to insert into the block with the small end inserted against the lifter to apply downforce on the cam ,one on each side. They have a heavy spring pressure and they remove any slack if you will from the cam to set the valve lash
Old 04-11-2020, 08:09 PM   #6
skidmarks
skidmarks's Avatar
Basically locking the cam from turning
skidmarks is offline   Reply With Quote
Old 04-11-2020, 08:24 PM   #7
Ken/Alabama
It will turn but they keep it centered.
Old 04-11-2020, 08:35 PM   #8
skidmarks
skidmarks's Avatar
Keeping it centered on the low side of the lobe? Do you re arraign it for each lobe?
Old 04-11-2020, 09:10 PM   #9
Ken/Alabama
Could be. They didn’t come with any instructions.
Old 04-11-2020, 11:53 PM   #10
Tinker
Tinker's Avatar
neat.
Old 04-12-2020, 12:31 AM   #11
Russ/40
Russ/40's Avatar
Makes no sense at all.
