Old 07-17-2019, 01:04 PM   #1
ncauclair
Default 292 312 Ford Engine
Hi
I have a 292 312 engine. It has a serial number on an original manifold as follows " ECE-9431-8 8 An odd looking "C" symbol with another symbol inside the C and a 4E 26. Anyone have any idea what year Ford the engine came out of? Also where would an engine number be located. Thanks Nick
ncauclair is offline   Reply With Quote
Old 07-17-2019, 01:19 PM   #2
40cpe
40cpe's Avatar
Default Re: 292 312 Ford Engine
The chart in this link shows the manifold to be from a '55 or '56 272" engine.
http://www.y-block.info/casting/exhaust.html
40cpe is offline   Reply With Quote
Old 07-17-2019, 03:11 PM   #3
dmsfrr
dmsfrr's Avatar
Originally Posted by ncauclair View Post
Hi
The various parts of an engine (like that exhaust manifold) have their own casting numbers.
Some parts were used on different year & displacement engines and the casting numbers could carry on for a couple years until Ford saw the need to change them.
Not to mention parts from 'wherever' being swapped around in the 60+ years since then.
A misc info and casting number link...
http://www.y-block.info/main.html
The casting number on the engine block itself is the one to look for.
... where would an engine number be located. ...
There may be three different locations depending on the year and foundry.
Go to the "Block Identification" tab (with a few photos) at this link...
http://ford-y-block.com/technical.htm
The "CF" symbol is for the Cleveland Foundry, as opposed to the Dearborn Industrial Foundry "DIF".
The "4E 26" is the date code of when the part was made, 4 = '54, E = May, and 26 would be the 26th day of the month. IIRC
dmsfrr is offline   Reply With Quote
Old 07-17-2019, 03:27 PM   #4
KULTULZ
KULTULZ's Avatar
Post Re: 292 312 Ford Engine
It has a serial number on an original manifold as follows ECE-9431-8 8
That will be found in the offered EXH MAN Casting I.D. CHART - ECE-9431-B
An odd looking "C" symbol with another symbol inside the C and a 4E26
The first identifies it as being cast at the CLEVELAND FOUNDRY and the second the DATE of CASTING.
The CASTING ID NO. identifies the EXH MAN as being a 272CI.
- WHY IS IT ... -
... that everything you buy in the grocery store is either wrapped in or contained in plastic but the government doesn't want you to carry it out in a plastic bag?
WONDERING IN W(BY GOD)V ...
DIAGNOSED CDO - (OCD In Correct Alphabetical Order)
KULTULZ is offline   Reply With Quote
Old 07-17-2019, 04:35 PM   #5
ncauclair
Wow. A great brain bank of knowledge. Thanks for all the info. So it's not a 292 312-- it's a 272. Cool. Big thanks.
Old 07-17-2019, 04:38 PM   #6
ncauclair
thanks so much for the info. Cheers Nick
Old 07-17-2019, 04:51 PM   #7
dmsfrr
dmsfrr's Avatar
... So it's not a 292 312-- it's a 272. Cool. Big thanks.
Did you find the actual engine block number? It will be 3 letters usually followed by '6015'.
Those ECE exhaust manifolds will bolt on to almost any other Y-block engine thru '64.
A 272 will have the letters "ECG" on the block, usually at the base of the distributor. Also the 'DIF' symbol.
Old 07-17-2019, 07:54 PM   #8
ncauclair
Can't find any symbols on the block??
Old 07-17-2019, 08:08 PM   #9
darrell
look above the oil filter.
darrell is offline   Reply With Quote
Old 07-17-2019, 08:54 PM   #10
dmsfrr
dmsfrr's Avatar
Upside down on the outside of cyl #1 just above the block drain petcock?
Old 07-18-2019, 08:16 AM   #11
all american boy
all american boy's Avatar
It can be bored out .060" to make it a 292.
Those are heavy engines.
What tranny do you have with it?
If it is a manual that is a good thing.
The automatics were god awful heavy because it was cast iron case with cast
iron bellhousing.
Good thing if it has a 4 barrel carb and intake manifold already on it.
Hang on to that engine even if you just store it under tarp.
They do not grow on trees anymore.
'Has racing made you a millionare?'
'Yes it has.Before I was a multi-millionaire.'-Quote
all american boy is offline   Reply With Quote
Old 07-18-2019, 09:04 AM   #12
svmsr1044
What is a ECZ 9425B intake manifold?
svmsr1044 is offline   Reply With Quote
Old 07-18-2019, 09:14 AM   #13
darrell
57 4 bbl.
Old 07-18-2019, 10:58 AM   #14
scicala
scicala's Avatar
It's also the best one for performance that came from the factory. There are better aluminum ones available too.
Sal
Old 07-18-2019, 11:51 AM   #15
dmsfrr
dmsfrr's Avatar
Originally Posted by darrell View Post
57 4 bbl.
Originally Posted by scicala View Post
It's also the best one for performance that came from the factory. ...
It accepts the larger bolt pattern '57+ 4bbl carburetors and has slightly larger / better flowing passages than the earlier 4bbl versions. (ECZ-A, ECB-B & EBY-D)
Old 07-18-2019, 01:20 PM   #16
bobss396
bobss396's Avatar
Like every Chevy engine for sale is out of a Corvette... any Y-block for sale is a 312.
bobss396 is offline   Reply With Quote
Old 07-18-2019, 03:31 PM   #17
KULTULZ
KULTULZ's Avatar
Exclamation Re: 292 312 Ford Engine
It (ECE-9431-B ) identifies that particular EXH MAN only. You need to ID the rest of the components to actually know what you have. It just might be a 312 under there.
Too much guessing and too little fact.
- WHY IS IT ... -
Old 07-18-2019, 04:16 PM   #18
ncauclair
I took a photo of the number on the block below the distributor. Had the Cleveland symbol and a 35 number. I tried to post the engine photos here but it won't let me????
Old 07-18-2019, 04:18 PM   #19
ncauclair
Found it below the distributor-- a Cleveland symbol and a 35 number? Tried to post a photo but site wouldn't let me?
Old 07-18-2019, 04:28 PM   #20
KULTULZ
KULTULZ's Avatar
What was the letter code? 35 is the CASTING MOLD NO used.
- WHY IS IT ... -
Thread Tools
Display Modes
