Old 05-21-2018, 01:51 AM   #1
Hoogah
Hoogah's Avatar
Default Hub bolts/Wheel studs - when to replace?
I have to replace two rear wheel studs/hub bolts due to their threads being toast. I cannot get proper tension on the lug nuts without them slipping.
Naturally this has me thinking (worrying) about the rest. I have visually inspected each one and come to the conclusion that it's pretty hard to tell when the threads have "crossed that line", as there is a range of presentations!
Brattons website suggests a wheel lug nut torque of 50-55 foot pounds. Should I just use the torque wrench at that setting and assume that the stud is OK if I get no slippage?
How would you make this decision?
Hoogah is offline   Reply With Quote
Old 05-21-2018, 08:04 AM   #2
BILL WILLIAMSON
BILL WILLIAMSON's Avatar
Default Re: Hub bolts/Wheel studs - when to replace?
IF I were in doubt, I'd replace them ALL & in the beginning, use a little LIGHT OIL, on the threads.
Bill Safe
"THE ASSISTANT GURU OF STUFF"
Old 05-21-2018, 09:57 AM   #3
Synchro909
Synchro909's Avatar
Wheel studs are cheap. It costs a few $ to remove the old and install the new but overall, the cost is trifling compared to the potential consequences. IMHO.
I'm part of the only ever generation with an analogue childhood and a digital adulthood.
Old 05-21-2018, 10:11 AM   #4
BILL WILLIAMSON
YES, PIZZA gets to the house BEFORE the Police, they gotta' EAT TOO!
Bill Accommodating
Old 05-21-2018, 12:20 PM   #5
Ruth
Bill Accommodating
Old 05-21-2018, 07:50 PM   #6
Tom Wesenberg
Tom Wesenberg's Avatar
Check the lug nuts, as they might be shot. Some of the repro nuts are too loose.
Old 05-21-2018, 08:27 PM   #7
Benson
Benson's Avatar
I agree with Tom W.
See info from Vince Falter's site.
http://www.fordgarage.com/pages/dangerouslugnuts.htm
Notice that Vince posted this in 2002 ... so problem has been going on for long time.
There are many bad nuts floating around at swap meets ... many people trying to purge these junk parts.
Benson is offline   Reply With Quote
Old 05-22-2018, 09:16 AM   #8
MAG
MAG's Avatar
Agree with Post 6.
I noticed the harder I work the luckier I get!
MAG is offline   Reply With Quote
