Old 07-01-2013, 01:31 PM   #1
msmaron
msmaron's Avatar
Send a message via AIM to msmaron
Default RE-VIST....Who makes the "Best" Tubes????
Ok need new tubes and this is an old subject but who is making the best now..Blew 3 already...
Mark Maron
Ill., Region MARC & MAFCA
MARC JSC Member
2022 Morgantown National Meet Chief Judge
National Facebook Admin.
https://www.facebook.com/groups/MARC.group/
A7191-Sport Coupe
29 Roadster
29-Town Sedan
msmaron is offline   Reply With Quote
Old 07-01-2013, 02:00 PM   #2
BRENT in 10-uh-C
BRENT in 10-uh-C's Avatar
Default Re: RE-VIST....Who makes the "Best" Tubes????
Mark, to my knowledge, the only person that is making tubes for Model-A tire sizes is Coker.
Most problems that I am finding is the tube stem is detaching. The way to correct this problem is to install metal valve stems. If the inside of the wheel is free from pits and shaft edges, and if the tube is properly installed with plenty of Talc, then I haven't experienced problems.
BRENT in 10-uh-C
www.model-a-ford.com
...(...Finally Updated!! )
Old 07-01-2013, 02:43 PM   #3
msmaron
msmaron's Avatar
Brent EXACTLY what happened to me...thanks for that
mark
Mark Maron
MARC JSC Member
A7191-Sport Coupe
29 Roadster
29-Town Sedan
Old 07-17-2013, 09:24 AM   #4
Walt Bratton
About 10 years ago we at Brattons started making our own inner tubes because we had issues with the tubes that were currently on the market. When we had one of the tubes analyzed we found out that those tubes were being made with a high percentage of recycled rubber, and the thickness was severely lacking. So when we had ours made we had these tubes made with 100% new rubber and much thicker for longer life. Since we have started making and selling our own tubes the failure rate has decreased. I know the tubes are a bit more expensive than the others on the market, but we have had much better success with them.
Walt Bratton is offline   Reply With Quote
Old 07-17-2013, 09:41 AM   #5
RockHillWill
RockHillWill's Avatar
Hey Walt, GREAT to see you here, you are one of the 'good guys' in our hobby and I want to thank you for that. You at Brattons have played a great part in my restorations and I want to thank you for that as well.
Jeff and Debbie took the time to stop by the Panel Delivery in Lexington and had her picture taken with me. I appreciate them doing that. I also appreciate your giving me the opportunity to 'test' some of your prototype stuff, and it's always been of the highest quality, and I continue to use a great deal of your pieces for my component restorations for other folks use as well as my own.
I hope this is not sounding like a commercial, but I have been a HUGE fan of yours for over 15 years, when I was restoring a Wide Bed pickup for Fine Point judging. I had ordered the wrong date put on all my glass pieces and it was getting down to the wire, time wise, for taking it to Indianapolis. I called your place and Jeff stayed late, re-cut and re-etched the dates and overnighted them to me. I was very impressed with his effort and you are my go-to guys for that reason ever since.
I am building a new aluminum bodied speedster, and I will be getting some of those new tubes for sure. I used the Bratton tubes on the Panel Delivery, and after sitting for a year since Oshkosh. one tire was down one pound and one other was down 2 pounds. The others held the same pressure as when I unloaded form Oshkosh. I had to cut and install the tubes for the new valve stems, and I bet that that small leak was my fault.
Thank you Walt!
Uncle Bud says "too soon old, too late smart!"
RockHillWill is offline   Reply With Quote
Old 07-17-2013, 09:48 AM   #6
ken ct
Depending on size,try a motorcycle shop their tubes are good quality usually and some are made in Japan.Not like China made ones.Some even have metal stems. ken ct.
ken ct is offline   Reply With Quote
Old 07-17-2013, 11:05 AM   #7
Gary Karr
Gary Karr's Avatar
Good to hear Brattons has them and that they are a better quality. That's where I'll go.
Gary Karr is offline   Reply With Quote
Old 07-17-2013, 11:41 AM   #8
H. L. Chauvin
Hi Mark,
No doubt many have bought & reported less desirable tubes in the very recent past.
Because of these reports, about a month ago, I called this same gentleman who replied in message #4 about where to acquire good tubes.
He responded like that of message #4.
In knowing that like many of our sincere Model A parts vendors, they sincerely earnestly try to provide the "best" available on the market -- this insures repeat customers -- appears crooks don't last long in today's economy.
I ordered & received (5) new tubes; installed one (1) new tube to replace one old leaking tube -- tubes looked thick & resilient -- it does "not" leak -- looks nothing like a Dollar Store helium filled Birthday Balloon.
Kept the old 30 year old tube because only the stem was leaking near the tube; & ordered a new metal stem.
Hope this helps to keep air in your tires.
H. L. Chauvin is offline   Reply With Quote
Old 07-17-2013, 01:33 PM   #9
BrianM
BrianM's Avatar
I installed a new set of Lester tires (all 5) & used Bratton's tubes. No failures, no leaks, no issues..... I don't even have to keep topping them up...very happy with them!
BrianM is offline   Reply With Quote
Old 07-17-2013, 02:38 PM   #10
Patrick L.
Patrick L.'s Avatar
Get some motorcycle tubes.
Old 07-17-2013, 02:46 PM   #11
johnbuckley
johnbuckley's Avatar
Which m/cycle tubes have our sizes in centre valve?
johnbuckley is offline   Reply With Quote
Old 07-17-2013, 03:28 PM   #12
ken ct
OPPS i forgot about that fact. All MC tubes have the valve in center of tube.as far as i know . None are off-set if thats what you need. Sorry. ken ct
Old 07-17-2013, 04:00 PM   #13
johnbuckley
I've looked many times in the past for m/cycle tubes that would fit 4.75/500x19 and for 4.50x21 can some one direct me a link to a decent site that sells them , Many thanks
Old 07-17-2013, 04:35 PM   #14
H. L. Chauvin
Concerning message #8, here is some of the "Rest of the Story":
I subsequently also asked Mr. Bratton what were his particular thoughts about trusting old Model A tubes of unknown origin.
Reply: Maybe Ok if one does not mind taking a chance on getting a blow out at about 45 mph, going in the ditch, & turning over with one's (4) wheels spinning in the air -- this really does not sound like a very safe thing to try.
Safe advice in my opinion.
Old 07-17-2013, 07:13 PM   #15
modelAtony
modelAtony's Avatar
Hello Walt. Glad you have been showing up here. I had gotten some bad tubes That came from some guys in our club, I had also ordered some from another supplier because a member was ordering . My bad tubes were about 3- 4 years ago I would mount them and about 2-5 days they were flat all the tubes were slit down the seams, rotten I guess. I then started buying all my tubes from BRATTON and haven't had a flat in 3 years I drive my car about 13,000 miles per year and more.NOT SAYING ALL THIS BECAUSE WALT IS HERE JUST THE FACTS. have fun modelAtony tony white Lafayette,LA
modelAtony is offline   Reply With Quote
Old 07-17-2013, 07:20 PM   #16
Mitch//pa
According to brattons website 19" Tubes with metal stems seemed to be brought in and not made by them. Is this correct??
Old 07-17-2013, 07:32 PM   #17
montanafordman
montanafordman's Avatar
Its great to hear from our parts suppliers once in a while. Even if they keep their opinions to themselves its nice to know they have an ear to our hobby and our concerns. I ordered a set of 5 tubes from Bratton's almost a year ago based on what was written about them and the stories of bad tubes people were experiencing. They have been holding air since last fall and I haven't touched them. About 800 miles and no trouble whatsoever. I did order the metal stem tubes which on the whole it seems people have less trouble with but this has been my experience.
Aaron in Tacoma
(although still a Montana hillbilly at heart )
montanafordman is offline   Reply With Quote
Old 07-18-2013, 07:35 AM   #18
Walt Bratton
Mitch we take a rubber stem tube and cut the rubber stem out of the tube and insert metal stems with the correct marking on them.
Old 07-18-2013, 08:03 AM   #19
BRENT in 10-uh-C
I agree 110%!!
BRENT in 10-uh-C
Old 07-18-2013, 08:39 AM   #20
Mitch//pa
walt thanks for that info,,, thats what i was looking for;;;;;
Thread Tools
Display Modes
