Old 12-14-2020, 12:04 PM   #1
Ordsgt
Ordsgt's Avatar
Default front brake backing plate
Need a reference to order of disassembly to remove, 1930 Ford Tudor backing plate from the car
Ordsgt is offline   Reply With Quote
Old 12-14-2020, 01:50 PM   #2
BRENT in 10-uh-C
BRENT in 10-uh-C's Avatar
Default Re: front brake backing plate
Have you removed the wheel and the brake drum/hub assembly from the spindle yet?
BRENT in 10-uh-C
www.model-a-ford.com
...(...Finally Updated!! )
Old 12-14-2020, 02:38 PM   #3
Ordsgt
Ordsgt's Avatar
drum/hub off and brake shoes off. Need backing plate off to install new roller tracks
Old 12-14-2020, 03:08 PM   #4
31Tudor
31Tudor's Avatar
Then next you would take the cotter key, nut, off the brake wedge at the bottom of the backing plate. Remove the wedge, and the long brake pin will be floating around and usually drop down when you remove the brake wedge. comes down through the spindle. Then remove the 4 cotter pins, and 4 castle nuts holding it on. Depending on your wrench set up, some bolts can be kind of tricky to get to. Just takes patience and you will need to hold the heads of the bolts from turning as well. then it should come off. There will be a little felt washer, between the backing plate and the spindle.
31Tudor is offline   Reply With Quote
Old 12-14-2020, 04:19 PM   #5
Ordsgt
Ordsgt's Avatar
Thanks, that is exactly what I needed to know
