Old 05-13-2020, 05:55 PM   #1
svmsr1044
Default 56 Sunliner question
Are there supposed to be cover panels for the access openings on the interior side of the doors on a 56 Sunliner??
svmsr1044 is offline   Reply With Quote
Old 05-14-2020, 07:41 PM   #2
paul2748
paul2748's Avatar
Default Re: 56 Sunliner question
I know that the 56 Birds have them.
48 Ford Conv
56 Tbird
54 Ford Victoria
Old 05-14-2020, 10:46 PM   #3
Daves55Sedan
Daves55Sedan's Avatar
If you are talking about the large rectangular holes in the door structure on the inside, the factory used a tar impregnated wafer board. Insert the board thru the slots on both sides of the opening and use three screws at the top to hold them in place. The factory used tacks there, but they fall out. I replaced mine with countersunk screws. For the waferboard, I substituted a piece cutout from roofing felt (cut to the same size and shape as the original waferboard.
BTW, all the '55/56 car models have this access hole and treated the same way.
