07-29-2019, 09:13 PM | #1 |
Rear Lower Trunk Panel
Does anyone know if any of the vendors sell a Coupe rear lower trunk panel with the correct arch built in? I've looked for an original but so far no luck. On a 30-31 coupe this panel is taller in the middle by about a 1/4" compared to the ends. I believe most of the reproduction panels are straight across both top and bottom and need extensive work to fit properly. TIA
Tony |
07-30-2019, 10:33 AM | #2 |
Re: Rear Lower Trunk Panel
That would be nice. More to the needed shape then just the top edge though.
07-30-2019, 09:06 PM | #3 |
Try Bert's. They have a lot of original panels. JP
07-31-2019, 05:01 AM | #4 |
I’d check with Bert’s on an original
However, I am currently completing a buck/template to make them correctly Made a first run yesterday and have to make some minor adjustments These have the correct arches etc. I have several originals to knock off from Should have them in two week if all works out. Will be $95 plus shipping to wherever These fit 28-29 coupe and all cabbys If any interest get back to [email protected] |
07-31-2019, 06:57 AM | #5 |
Had a problem with repro panel being straight across the top. Could't find a good original replacement, but did find a bad original from which I took the top reinforcement bar and spare tire reinforcement and installed same in place on the repro panel which solved the problem.
07-31-2019, 07:42 AM | #6 |
That’s why I went the path of making them We shall see how it goes |
07-31-2019, 10:30 AM | #7 |
Thanks gentlemen I appreciate the advice.
08-01-2019, 11:02 PM | #8 |
08-02-2019, 10:27 AM | #9 |
Thanks Steve, great info.
