Old 10-09-2020, 10:22 AM   #1
adileo
adileo's Avatar
Default 52 F1 motor mounts
Hey guys
I need to replace front motor mounts. Pretty simple I’m thinking but want to double check with those who have done it many times before.
Cotter pin out loosen/remove castle nut.
Place 2x4 on floor jack - roll under oil pan and lift engine, a couple inches.
Tap old bolt until able to remove top biscuit.
Work under truck and remove lower biscuit
Do reverse for install.
Sound right? Any suggestions or miss anything?
As always thanks in advance!
Thanks
Andy
1952 F1
adileo is offline   Reply With Quote
Old 10-09-2020, 10:37 AM   #2
skidmarks
skidmarks's Avatar
Default Re: 52 F1 motor mounts
Jack the motor up just enough to change the biscuits.
A couple inches , your radiator and exhaust wont like it.
skidmarks is offline   Reply With Quote
