10-04-2020, 04:40 AM | #1 |
50 ford woodie chassis finally in derusticator!
The title says it all, I finally built the tank to do electrolysis on my 50 woodie chassis. The beauty of this process is there is no metal spread or integrity compromise, all it takes is time. The process is nothing but a chemical reaction created using washing soda and water, and is activated with an anode connected to the positive side of a charger, and the part being cleaned to the negative side.
10-04-2020, 05:36 AM | #2 |
Re: 50 ford woodie chassis finally in derusticator!
Can’t wait to see the final product.
10-04-2020, 06:14 AM | #3 |
I just did a engine block and was very pleased with how well it worked. Good luck
10-04-2020, 07:45 AM | #4 |
Looks like a plywood box with a plastic liner, very simple. Please post results, interesting.
Tom |
10-04-2020, 08:56 AM | #5 |
The main knock on electrolysis derusting is that it works "line of sight" only. (You have to have direct access between the cathode and the piece being derusted.) I have used this method myself, and found it effective (though a little messy) when working with individual parts where you can surround the part completely.
I am wondering what you guys have done about this (especially with an engine block). |
10-04-2020, 03:28 PM | #6 |
10-04-2020, 03:29 PM | #7 |
48, Ive done several engines this way, and its the only way to go!
10-05-2020, 01:56 AM | #8 |
I have used the method in the past and I prefer it to anything. I still have to get a couple of those mesh grids that are used to reinforce concrete for driveways etc. Going to make up a basket to put in my tank. All four sides and a bottom should do the trick!
