Old 09-10-2020, 05:16 PM   #1
LEM
LEM's Avatar
Default 1/2” Bendix
I need a new Bendix for my 28’ starter motor but I cannot find a new one for a half inch shaft. Can one be purchased? Or can a sleeve be pressed into the 5/8” Bendix?
LEM is offline   Reply With Quote
Old 09-10-2020, 09:18 PM   #2
Mike Peters
Mike Peters's Avatar
Default Re: 1/2” Bendix
Distributor bushings re .5" ID. Don't know if that would work for you. Or have a custom bushing/sleeve made. Use a later starter with the 5/8" shaft? Different switch, however.
Mike Peters is offline   Reply With Quote
Old 09-11-2020, 09:43 PM   #3
Chuck Sea/Tac
Chuck Sea/Tac's Avatar
I’ve seen shaft adopters (sleeves) for electric motors
Old 09-12-2020, 08:55 AM   #4
supergnat
supergnat's Avatar
There is great bendix info on pages 570 to 572 of the Service Bulletins. As far as I know you cannot use a starter with a 5/8 shaft in place of the 1/2 inch shaft type without modifying the flywheel. Perhaps someone has a bendix available for a 1/2 starter. Post of photo or your damaged bendix someone may have a stash of old parts. good luck Supergnat
supergnat is offline   Reply With Quote
Old 09-12-2020, 09:03 AM   #5
jw hash
jw hash's Avatar
sent PM
jw hash is offline   Reply With Quote
Old 09-13-2020, 09:21 PM   #6
Doug Linden
Doug Linden's Avatar
The issue is that it is not a Bendix starter drive, the 1/2" shaft used an Able starter drive which are not available. Easier to change to a starter with a 5/8" drive.
Doug Linden is offline   Reply With Quote
Old 09-13-2020, 10:06 PM   #7
GRutter
GRutter's Avatar
It is my understanding that you cannot change to a starter with a 5/8" drive, as the gear diameter is larger, even though both are 10 teeth.
I would post what you need in the wanted forum. Check with Berts. Look on eBay.
I do not believe parts are available for these from our vendors.
GRutter is offline   Reply With Quote
Old 09-14-2020, 07:34 AM   #8
johnbuckley
johnbuckley's Avatar
Originally Posted by GRutter View Post
It is my understanding that you cannot change to a starter with a 5/8" drive, .....
Really? The service manual suggest that they are a straight swop... or am I misreading it?
johnbuckley is offline   Reply With Quote
Old 09-14-2020, 09:27 AM   #9
supergnat
supergnat's Avatar
The Page 284 of the service bulletins announces a new 1/2 inch starter assembly A-18475 with the new Special Drive installed. That can be a direct swap. The 1/2 shaft of the starter armature was machined to accommodate the new Special Drive. My October 28 Leatherback has the special drive (1/2 shaft which replaced the Abel drive which was used from Oct 28 until Ford transitioned to the 5/8 shaft starter drive Bendix drive which was then used until the end of production. Special Drive A11350-DR. See pages 303-305 of the Service Bulletins for more information
Old 09-14-2020, 09:37 AM   #10
Kurt in NJ
Kurt in NJ's Avatar
Be careful, 1/2" is the size for model T, but it spins the other direction
Old 09-14-2020, 02:02 PM   #11
johnbuckley
Originally Posted by supergnat View Post
The Page 284 of the service bulletins announces a new 1/2 inch starter assembly A-18475...... until Ford transitioned to the 5/8 shaft starter drive Bendix drive which was then used until the end of production. Special Drive A11350-DR. See pages 303-305 of the Service Bulletins for more information
Ah, Thanks for that clarification I thoght I was misssing something!
Old 09-14-2020, 10:11 PM   #12
GRutter
GRutter's Avatar
Found these starter parts on ebay this evening. Someone with an early 28 needs these parts.
https://www.ebay.com/itm/Model-A-For...%7C3000%7C7000
Thread Tools
Display Modes
