07-06-2020, 01:33 PM | #1 |
59 AB camshaft install Help
Had a couple of flat lobes on a stock 59 AB cam. got a nice used 59 cam to replace it. lifters out, oil pump out. Cam is most of the way in, lacking about 1/2". Won't go in the rest of the way. Never done this before. Please let me know what I'm doing wrong, or need to do. Thanks Ron
07-06-2020, 02:24 PM | #2 |
Re: 59 AB camshaft install Help
Not much help on your cam issue, but what lifters are you going to use? Reusing lifters is questionable and especially the ones that were associated with the bad lobes.
07-06-2020, 03:00 PM | #3 | |
Sounds like the oil pump idler gear may be the reason the cam is not going in the rest of the way. If you remove the rear cover on the block you can turn the idler gear so the gear teeth line up. Or another way would be turn the crankshaft while pushing on the cam gear at the same time. The cam oil drive gear teeth will eventually line up with the idler gear then the cam will fall right in nicely. Ronnieroadster
I use the F word a lot no not that word these words Flathead , Focus and Finish. "Life Member of the Bonneville 200 MPH Club using a Ford Flathead block" Owner , Builder, Driver of the First Ford Flathead bodied roadster to run 200 MPH Record July 13, 2018 LTA timing association 200.921 in one and a half miles burning gasoline. First ever gas burning Ford flathead powered roadster to run 200 MPH at Bonneville Salt Flats setting the record August 7th 2021 at 205.744 MPH |
07-06-2020, 03:01 PM | #4 |
Do you have the fuel pump pushrod still in place
Chuck |
07-06-2020, 04:05 PM | #5 |
Maybe put the oil pump back in to provide a little resistance on the idler gear so it won't turn as easily with the cam shaft as you try to align the gears.
07-06-2020, 04:29 PM | #6 |
