07-09-2020, 02:43 PM | #1 |
Electric fuel pump test ?
Is it possible to test the pressure put out by my electric fuel pump ?
I would like to know how much fuel pressure I have at the carb. I am not running a mechanical pump, just the electric one. |
07-09-2020, 03:18 PM | #2 | |
Re: Electric fuel pump test ?
Type of carb in use will dictate required pump discharge pressure. Too much may cause leak by and too high float level. Phil NZ |
07-09-2020, 03:23 PM | #3 |
I fitted a pressure regulator to my electric 4 psi pump, have no mechanical pump either. Tested it right now and it seemed to help my carburation - no stinking/black smoke anymore and gained another 10 km/h.
cheers, Harty |
07-09-2020, 03:47 PM | #4 |
This help
Thanks Andy 1952 F1 |
07-09-2020, 04:49 PM | #5 | |
You sure can its easy to do using any type of low pressure gauge. To test the pressure output from the pump no need to add a Tee fitting. All you need to do is connect the fuel line thats on the carb directly to the pressure gauge. Once you turn the pump on you will see the pressure output on the gauge from the pump. Some electric pumps will shut down once the flow stops so the pressure reading will go down once that happens. Prior to that you will see the pressure reading on the gauge. Ronnieroadster
I use the F word a lot no not that word these words Flathead , Focus and Finish. "Life Member of the Bonneville 200 MPH Club using a Ford Flathead block" Owner , Builder, Driver of the First Ford Flathead bodied roadster to run 200 MPH Record July 13, 2018 LTA timing association 200.921 in one and a half miles burning gasoline. First ever gas burning Ford flathead powered roadster to run 200 MPH at Bonneville Salt Flats setting the record August 7th 2021 at 205.744 MPH |
07-09-2020, 05:37 PM | #6 |
