Old 09-29-2019, 07:24 PM   #1
Nick in Fayetteville
Default No nut manifold clamp
Has anyone had experience with the "no nut" exhaust manifold clamp. I have one ordered but it hasn't arrived yet. Looks like a lot better way to secure the manifold to the exhaust pipe. Time will tell.....
Nick in Fayetteville is offline   Reply With Quote
Old 09-29-2019, 07:33 PM   #2
Purdy Swoft
Purdy Swoft's Avatar
Default Re: No nut manifold clamp
Sounds like a good thing . I have no experience with it yet .
Old 09-29-2019, 07:37 PM   #3
ryanheacox
ryanheacox's Avatar
Haven't heard of or seen it. Can you post a link?
ryanheacox is offline   Reply With Quote
Old 09-29-2019, 08:32 PM   #4
WTSHNN
WTSHNN's Avatar
No experience with it either but here's the link.
https://www.snydersantiqueauto.com/P...earchByKeyword
-tin
No one wants advice - only corroboration.
-John Steinbeck
WTSHNN is offline   Reply With Quote
Old 09-29-2019, 09:27 PM   #5
PalAl
PalAl's Avatar
I have had the "No Nut Clamp" on my car for about three years, works very well, easy to use and has an excellent seal. Got mine from Red Quail Early Ford Parts along with several other parts. Here is the link for their web site.
https://www.redquailearlyfordparts.com/ Nice people to deal with.
PalAl is offline   Reply With Quote
Old 09-30-2019, 12:20 PM   #6
Purdy Swoft
I suppose that it would be easy enough to braze nuts on one side of the clamp and make my own .
Old 09-30-2019, 02:47 PM   #7
SAJ
SAJ's Avatar
On RHD cars the steering column leaves little space for the manifold clamp and bolt plus nut. So I braze a stud into the clamp (Just a bolt with the head cut off) and use a nut only. Otherwise the bolt head can interfere with the oil drain tube bolt when rotated to miss the clutch pedal shaft as the pedal is operated. This way a brass nut can be used which will not rust and seize as steel nuts can.
SAJ in NZ
SAJ is offline   Reply With Quote
Old 10-06-2019, 06:56 PM   #8
Got mine from Snyder's. Went on easy. Seals tight. The only one that I'll use from now on...Nick
Old 10-07-2019, 09:26 PM   #9
ModelAMike1930
ModelAMike1930's Avatar
I have one also got mine on ebay a few years ago works great. Its the only kind I would use now.
ModelAMike1930 is offline   Reply With Quote
Old 10-08-2019, 05:28 PM   #10
Dodge
What a great idea. Thanks.
Dodge is offline   Reply With Quote
Old 10-08-2019, 10:17 PM   #11
Ray in La Mesa
I went the other way, dropped the bolts into one side of the clamp & braised the heads to the clamp, works great, didn't have to buy a new clamp. Then I aligned them to fit the other 1/2. seems like it would be easier to align both halves with the bolts through them.
Ray in La Mesa is offline   Reply With Quote
Old 10-12-2019, 08:13 PM   #12
Chuck Sea/Tac
Chuck Sea/Tac's Avatar
I really don’t see, or have, a problem with the original design. I can see how it’s a bugger on the RHD though.
Old 10-14-2019, 11:54 AM   #13
Purdy Swoft
Using a socket and a ratchet on a no nut clamp should be easier than having to use two pieces when a bolt and NUT is used . Though I have installed a lot of original exhaust manifold clamps , it was always a pain to me when having to reach around the clamp and hold the nut .
