Old 08-13-2019, 07:15 PM   #1
Denali
Default Leakless Water Pump
12 years or so ago, I rebuilt the motor on my 29 AA. I decided to buy a 'Leakless' water pump for whatever it was going for back then.
Well, my leakless pump is now leaking around where the packing nut is...
What should I do?
Mark in Fairbanks Alaska
Denali is offline   Reply With Quote
Old 08-13-2019, 07:28 PM   #2
Smooth_One
Smooth_One's Avatar
Default Re: Leakless Water Pump
Where did you purchase it from?
Isaiah B.
1928 all metal Tudor
Smooth_One is offline   Reply With Quote
Old 08-13-2019, 07:31 PM   #3
Smooth_One
Smooth_One's Avatar
Is it one of the James Rupert pumps?
His number is 661-589-5795
leaklesspumps.com
Isaiah B.
Old 08-13-2019, 08:05 PM   #4
Jacksonlll
Jacksonlll's Avatar
Send a message via ICQ to Jacksonlll
Most are not leakless. Some are built with just an O ring. You can try packing behind the nut, but if you run a leakless, you better have a spare for repair on a trip. With the old original, Easy to fix on the road.
Jacksonlll is offline   Reply With Quote
Old 08-13-2019, 09:09 PM   #5
Chuck Sea/Tac
Chuck Sea/Tac's Avatar
There were/are several different designs of “leakless” water pumps. If you’re mechanical, take it apart and see what style it is, and you’ll most likely be able to find parts and repair it. Otherwise buying or building a new pump is the answer!
Old 08-13-2019, 10:26 PM   #6
Tom Wesenberg
Tom Wesenberg's Avatar
I agree.
I rebuilt my pump as original, and it's been leakless for over 20 years. I now use the double lip seal in the rear bushing, to better keep the grease and antifreeze separate, but otherwise the pump is just like original.
Old 08-14-2019, 07:18 AM   #7
Chris in WNC
Chris in WNC's Avatar
If it came from James Rupert, he will refresh it after the warranty period for a much lower cost than his original unit......he's the best water pump guy I know of.
our next Model A is out there in the unknown......
Chris in WNC is offline   Reply With Quote
Old 08-14-2019, 07:20 AM   #8
Nosetime
Nosetime's Avatar
I believe the directions with mine suggested tightening the nut if a leak develops.
Nosetime is offline   Reply With Quote
Old 08-14-2019, 03:36 PM   #9
Denali
I will attempt to fix it after I take it apart. I dont recall who I bought it from. Mark
Old 08-15-2019, 02:06 PM   #10
Smooth_One
Smooth_One's Avatar
I bought mine from James. The HD pump (high dollar) it’s supposed to be leakless and maintenance free.
I called a few guys I know that had the same one and they’ve been running them for 15-20 plus years with no troubles.
Isaiah B.
Thread Tools
Display Modes
