Old 05-30-2019, 12:20 PM   #1
juke joint johnny
juke joint johnny's Avatar
Default lime scale removal
Whats the best way to clean lime scale from a radiator?
Will the Vinegar treatment work or is that just for rust?
It's an original 29 Round tube rad that doesn't leak so anything is worth a try
John Cochran
juke joint johnny is offline   Reply With Quote
Old 05-30-2019, 05:43 PM   #2
Synchro909
Synchro909's Avatar
Default Re: lime scale removal
There is a product available here for the removal of Calcium, Lime and Rust deposits. It's called CLR and is available from hardware stores and some groceries. Ask around - I'd be surprised if there is not something similar over there.
I cannot comment of whether vinegar will help.
I'm part of the only ever generation with an analogue childhood and a digital adulthood.
Old 05-30-2019, 06:15 PM   #3
30 Closed Cab PU
Other info - Best to treat with Washing Soda (not baking soda) or Dawn dishwashing detergent to initially get grease/oil out of it 1st.
If treating with vinegar while in the car and running the motor/cooling system, if leaks occur it most likely will ruin any paint it gets on. I am not sure what happens with CLR, may want to do a spot test somewhere 1st.
When using White Vinegar or anything acidic always do a final fill/flush with baking soda/water to neutralize the acidic content that has permeated within the cooling system.
30 Closed Cab PU is offline   Reply With Quote
Old 05-30-2019, 07:25 PM   #4
eagle
eagle's Avatar
Oxalic acid should work, available at Walmart.
"There are some that can destroy an anvil with a teaspoon and shouldn't be allowed to touch anything resembling a tool."
eagle is offline   Reply With Quote
Old 05-30-2019, 08:12 PM   #5
Cool Hand Lurker
Cool Hand Lurker's Avatar
I don't know if I would use Dawn or any other like product. It is concentrated so you could easily get too many suds. You would have to rinse it out with cold water a few times.
It is great stuff with hot water for cleaning out grease though.
Cool Hand Lurker is offline   Reply With Quote
Old 05-30-2019, 08:16 PM   #6
Synchro909
Synchro909's Avatar
it is great stuff with hot water for cleaning out grease though.
Suds can be an issue of you're driving any distance. The suds mean the coolant doesn't work properly an the engine overheats. I use a tablet from the dish washer. Removes the grease and no foam.
Old 05-30-2019, 10:04 PM   #7
30 Closed Cab PU
Oxalic acid works great, downside not very environmentally safe, get it on paint etc not good. Have to be very careful wearing gloves and do not get any on you or your cloths. Plus might be harsh on an original 29 round tube radiator, might cause it to leak.
I've used the dawn, works well, do not remember how much but yes do not overdo it. Did not leave it in long, performed the cleaning with the car sitting still at fast idle and kept an eye on the temp. Then used a hose/adapter/garden hose to back flush for an extended period. CLR or vinegar or what ever else used should flush out the dawn and should have no continuing suds issues.
I've also heard teh dishwasher tablet works well, but have not personally tried it.
Old 05-30-2019, 10:06 PM   #8
30 Closed Cab PU
And we still have not answered the OPs original question. Does White Vinegar remove scale?
Hopefully someone knows and will post the answer.
Old 05-30-2019, 11:20 PM   #9
PalAl
PalAl's Avatar
Yes, it will clean scale. I use it to clean my coffee pot, but have never had the need for my "A". Google it........... lots of info
PalAl is offline   Reply With Quote
Old 05-31-2019, 06:09 AM   #10
Ray64
Ray64's Avatar
I worked for ford 43 yrs. and used oxalic yearly on my cars to remove foundry fallout. Had no problems with paint. Just use some gloves to keep the burn down if you have a scratch or small cut Just my 2 cents RAY
Ray64 is offline   Reply With Quote
Old 05-31-2019, 06:27 AM   #11
juke joint johnny
Thanks for all the good advice !!!
Most Rad shops here would put a new core in it, but they wont rod one out anymore
Old 05-31-2019, 07:41 AM   #12
Terry, NJ
Terry, NJ's Avatar
Vinegar will work. But be careful about about starting leaks. Vinegar usually is 5% ascetic acid and it can start a pinhole leak. Don't ask me how I know !
Terry
Terry, NJ is offline   Reply With Quote
Old 06-01-2019, 11:32 AM   #13
abachman3
abachman3's Avatar
Yes Vinegar will work. Somewhat slowly. CLR is a bit quicker. Muriatic Acid (Hydrochloric Acid) is much quicker, but don't leave it in too long... use it at about a 4:1 dilution. (4 parts water.)
abachman3 is offline   Reply With Quote
Old 06-01-2019, 01:03 PM   #14
Tom Wesenberg
Tom Wesenberg's Avatar
Now, there is a safe way, and a dangerous way to mix an acid and water.
Which is the safe way?
Old 06-01-2019, 09:43 PM   #15
Brian in Wheeling
Brian in Wheeling's Avatar
add the acid to the water...not the opposite.
Brian W.
Brian in Wheeling is offline   Reply With Quote
