Old 10-17-2020, 08:46 PM   #1
Standing Elk
Default Anyone using a horn relay
I see that some of the suppliers offer a horn relay that fits inside the horn cover, claiming that it will help the performance of your horn. Has anyone used one of these? If so did it help? Thanks
Standing Elk is offline   Reply With Quote
Old 10-17-2020, 10:16 PM   #2
CWPASADENA
CWPASADENA's Avatar
Default Re: Anyone using a horn relay
I have been using one for several years now.
It made a difference in how the horn worked. I would recommend it especially if you have a 6 volt system.
Chris W.
CWPASADENA is offline   Reply With Quote
Old 10-18-2020, 05:16 AM   #3
Werner
Werner's Avatar
Hi Elk,
yes, I have one too. The horn works much more better also in idle. Easy and unvisible to install.
Werner
Ford Model A, Roadster, 1928
Citroen 11 CV, 1947
Hercules W 2000, 1976; (with NSU-Wankel Rotary Engine), Canadian version
Werner is offline   Reply With Quote
Old 10-18-2020, 07:15 AM   #4
KGBnut
KGBnut's Avatar
I have a non-standard, but period correct, horn (the Sparton was stolen long before I bought the car). I couldn't fit the relay inside the cover, so I put it inside the radiator shell. It still worked great and made the horn more reliable.
Style beats speed any day, and with a lot fewer tickets.
KGBnut is offline   Reply With Quote
Old 10-18-2020, 08:40 AM   #5
shew01
shew01's Avatar
Chris W.
Is this similar to what you have?
https://www.brattons.com/horn-relay.html
Do this work for 6 and 12 volts?
Old 10-18-2020, 09:06 AM   #6
KGBnut
KGBnut's Avatar
That is that the one that I have. My system is 6 volt, positive ground, with an original generator.
Old 10-18-2020, 09:16 AM   #7
Standing Elk
Thanks fellas, I believe I will try one.
Old 10-18-2020, 09:48 AM   #8
Badpuppy
Much the same as the one I got from Snyder's. 12V needs a 12V relay - the 6V will probably work with short bursts, just won't last as long.
The relay winding requires much less current through the horn button, so it can operate with less-than-perfect contact there.
Badpuppy is online now   Reply With Quote
Old 10-18-2020, 10:02 AM   #9
Will N
Will N's Avatar
I can see how this might work, depending on how the relay is wired, when the engine is off or the car is idling. When the engine is running at a speed where the generator is charging, the horn is wired right to the generator cutout and you have plenty of voltage to run the horn. If the wiring of this relay bypasses the generator cutout, terminal box, ammeter and starter switch terminal (which is the path the hot wire for the horn takes to the battery) and goes directly to the battery, with fewer possibly corroded connections that can cause voltage drops, it can be more reliable. But IMHO, this relay is just a band-aid. Bright and tight fellas! Clean those wire connections 'til they are shinning and snug them down, Clean the battery terminals and make sure you have a good ground and your horn will work as intended without adding yet another component that can go wrong.
Will N is offline   Reply With Quote
Old 10-18-2020, 11:47 AM   #10
Afordman31
Afordman31's Avatar
Have been using one since the late ninety's with no problems. If i remember right you had to work a bit to get it inside the horn. Yes the Bratton's one is like what I bought from Snyder's years ago.
Afordman31 is offline   Reply With Quote
